586,375 active members*
3,651 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > THK HSR bearing codes, Factory preload?
    Mar 2006
    I have a HSR35 slide it looks new, slides smoothly, but requires a lot of force. I assume it is preloaded. I have been unable to decipher the options form the THK site. Rail is marked - UGIE5 . Block is marked Y0112. Is it preloaded and can the preload be adjusted or removed?
    Mike
    Dec 2007
    379
    I do not know whether the preload can be changed but I suspect that if you can, it would just be a matter of using different sized balls to achieve higher or lower preload. One thing to try first is press down on the bearing block while sliding it. These rails, especially large ones like yours seem to need some load on them to get them to slide smoothly. Also make sure that the "rubber" seals on the blocks have some lube on them to as sometimes they can stick a bit.
    What are you planning to build with those massive rails?
    Sep 2005
    1195
    Linear motion
    I have a big one by Hiwin, it move and slide easily and smoothly, like no restriction. It is new one. I do not think if it needs preload, it looks like rigid, no side movement while sliding. Block is about 15 cm by 15 cm. Rail is about 8 cm by 8 cm. Thanks. Asuratman.
    Mar 2006
    Quote Originally Posted by LazyMan View Post
    I will try putting some weight on it. My original thought was to use it as a single rail , single block Z axis on a future gantry style machine. Since the block is ~5 1/2 inches long it should work as well as 2 small blocks. I looked at the specs but did not grasp the true size until it arrived. Now I am thinking of using it as a mini lathe bed or as the vertical on a mill.
    Mike
  1. preload on spindle bearing
    By adryan in forum Uncategorised MetalWorking Machines
    Last Post: 06-21-2010, 11:59 PM
  2. locknut for bearing preload
    By lagfish in forum Benchtop Machines
    Last Post: 01-11-2008, 10:57 PM
  3. Bearing Preload w/Lovejoy Connector
    By rcazwillis in forum Linear and Rotary Motion
    Last Post: 07-23-2006, 11:43 AM
  4. strange bearing preload thread on ballscrew
    By mxpro32 in forum Benchtop Machines
    Last Post: 03-22-2005, 08:23 PM
  5. strange bearing preload threads on ball screw
    By mxpro32 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-11-2005, 03:07 AM
