586,058 active members*
3,712 visitors online*
IndustryArena Forum > Hobby Projects > I.C. Engines > Model V8 engine plans required
Page 26 of 27 1624252627
Results 501 to 520 of 525
  1. #501
    Oct 2010
    110
    id be guessin its about 2 ft away
    ferpectly safe!
    braaaap only problem with a tube amplifier is you have to wait for it too heat up to hear this! :violin:
    right! so who is going to be mad enough to scale this....DOWN?
  2. #502
    Dec 2006
    603
    Quote Originally Posted by headsmess View Post
    How small are we talking? The big holdup would be the sparkplugs. If someone is crazy enough I have a design for a #6-56 plug and also have the insulators done.
  3. #503
    Jan 2007
    76
    Why would you bother when you can get these for about $10 each in quantity. Work well too.
    DL Engines and Hobby Australia - Spark Plug 1/4-32 (Fits glow plug)
  4. #504
    Dec 2006
    603
    Quote Originally Posted by bluejets View Post
    Because 1/4-32's are WAY too big. Would not fit into the cylinder and would look huge on the engine. #8's look big enough as it is. The design calls for a 8-40 plug. 6-56 plugs are not much smaller.
    1/4 - .250
    #8 - .164
    #6 - .138
  5. #505
    Oct 2010
    110
    im awwwwwstrawlian...wtf is a #6?
    going with thou, at 138 im assuming its equivalent to about... 3.5mm!
    so i guess you could manage a 3/4 scale without too much ...ugliness...
    yes? no?
    lets see, cube root of 50 is...um... tap tap tap... 3.... wheres my calculator?
    3.685. (i did see 50cc somewhere didnt i?)
    so 3/4 of 3.685...
    2.76375
    cubed is...
    21 or so cc?
    did i do that right?
    would that even be possible? about 2.5 cc a cylinder!
    actually, 3/4 of the 164 or #8 would be 123 thou, so #6 would be a tad oversize still... is there a #5?
    may be needing to invest in a straitjacket!
  6. #506
    Jan 2007
    76
    Yes, I am well aware of what you are trying to achieve. I do know what a #6 size refers to also. The reality is that some things, sparkplugs included have limitations on the amount of "scaling" they can handle and still work efficiently enough without being troublesome.
  7. #507
    Dec 2006
    603
    yes? no?
    so 3/4 of 3.685...
    2.76375
    cubed is...
    21 or so cc?
    Well the bore and stroke are .625 (15.8mm)
    So that is 25.1 cc
    3/4 scale would be a bore and stroke of .469 (11.9mm)
    So 10.6 cc
    Yes I would get that straight jacket ready.
  8. #508
    Dec 2006
    603
    That's very true. Also consider that an RC ignition can jump a 1/2 inch gap so controlling where the arc goes can be an issue. The smaller the plug the closer the tip gets to the block so ignition boots become a nessessity. If you look at any model engine the plugs never look scale under about 1/3rd scale.
  9. #509
    Oct 2010
    110
    you mean it IS 25 cc?
    ok...small enough already!
    where did i get 50cc from then?(chair)
    hmmm. revise maths. substitute 25, and yep. there you go. 10.6 cc. times by 6, poke some decimal places... .636 cu"
    definitely bordering on the limits of practicality. not only is there the spark factor, but im fairly certain you cant shrink a molecule of petrol... or air. surely atomisation / combustion becomes an issue at such sizes too? then again a cox .010 manages to run...
    but 1/2" BxS still sounds possible.... that would be... no! no more maths! give or take, 16 cc or a whole fat cubic inch
    how about diesel? bypass the spark problem and replace it with another? :wee:
    sorry. ill stop now
  10. #510
    Feb 2012
    15
    Steve, First of all Awesome job! This is my first post, even though I have been watching it for a long time. I have been a machinist for over 20 years and finally got the money to build my own shop at home. I have been tring to get in touch with you because I would love to have the plans for this engine for my first project. Please let me know and I will send the money right away!
  11. #511
    Dec 2006
    603
    Quote Originally Posted by stumpy1807 View Post
    Hello Stumpy! I sent you an Email but i will post the info here for anybody else who might have an interest.
    Plans can be purchased via Paypal by sending money to [email protected]
    After payment is confirmed I simply email the PDF to you. I send it to the
    email provided by Paypal. If you want it sent somewhere else leave me a note.
    Your first and last name will be saved as well as the address. If you ever have a
    problem like a hard drive failure and you have no backup, simply email me with
    your info and I'll send the latest version. Name and Email address need to match
    so remember where you had me send them.
    The engine is $50USD and includes the engine, display base, radiator, and fuel tank.
    There is a total of 68 pages in a single PDF file.
    The blower is $25USD and includes the blower, intake manifold, balancer modifications.
    There is a total of 27 pages in a single PDF file. I have not yet built the blower but
    I have made prototypes.
    The Little Demon V8 is designed to be a bench top display engine. It should not be used
    to power any type of RC vehicle because the cooling system is only adequate for short
    runs. It should only be run using gasoline + 5% WD40 and should never be run on nitro.
    Thank you!
    Steve
    stevehuckss396
  12. #512
    Feb 2012
    15
    Awesome!! Just sent you a payment!!
  13. #513
    Mar 2012
    WELL DONE STEVE !
    Yup,,I'm a newbie,,starting with nothing but the desire to , one day, be able to design and build a bottom end to take 2 x 250/4 top ends (bike)in a 90 degree V cofiguration.
    This thread is an inspiration to me,,,,
    NN (nuts)
  14. #514
    May 2004
    600
    Numbnutz,
    Now that's a neat idea! Just imagine 500cc, 32 valves and 19,000RPM!
    No doubt you've seen the (Hyabusa based) Radical SR8's and the Yamaha based RST V8's. Probably my favourite is the N.Z. made Synergy V8 based on ZX14 's.
  15. #515
    Mar 2012
    Quote Originally Posted by skippy View Post
    Numbnutz,
    Yeah mate,,iv'e perved on the 'busa V8
    I'm almost finished building a supercharged honda 250/4 for L S Racing (sorry guys,,its not a model)
    it sounds something like,,,,
    Supercharged CBR250R initial startup & run - YouTube
    NN(nuts)
  16. #516
    May 2004
    600
    Can't view photos of last post
    Can someone please tell me why I can't view the photos of the last post? I can view all photos in the other posts (and in other threads) but not this one. Is it only me that can't view them? Thanks for your help.
  17. #517
    Feb 2007
    4553
    Skippy,
    The reason why you can not see the images in the post prior to yours is because "RegiR4Bur" is posting spam and hopefully the moderators block his ip address. It is getting very frustrating sorting through a load of garbage every evening.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  18. #518
    May 2004
    600
    Thanks Jeff for shedding light on that for me. I thought I had something wacky with my system but luckily that's not the case.
  19. #519
    Jan 2009
    265
    Nice job Steve, love Edelbrock stripes.
  20. #520
    Oct 2006
    708
    Small yes; but smallest? Article title reads a little different from summary. Impressive still:
    World's smallest supercharged four-stroke V8 engine now in production - Images
    Now the smallest (quarter-scale) blown V8 gasoline engine in commercial production is being turned out by Conley Precision Engines to power.
  1. Engine Plans
    By nzer in forum MetalWork Discussion
    Last Post: 08-03-2012, 05:14 PM
  2. I.C. engine plans
    By cumminsman in forum I.C. Engines
    Last Post: 04-10-2012, 11:43 PM
  3. Does anyone have any good jet engine plans?
    By flyguy1254 in forum Hobby Discussion
    Last Post: 04-16-2010, 10:28 AM
  4. Jet Engine plans
    By godspeed in forum Hobby Discussion
    Last Post: 05-18-2007, 11:34 AM
