Originally Posted by
teamjnz
I have been trying to understand the information that I have been receiving. I and have been learning somethings too.
I learned that my Dry Run switch does work, but not in rapid mode. Is there a way to find out what my feed rate override is stuck on?
For example if I program a G1 line at F50. where do I look to see if the machine is moving at 50 inches a minute. I am assuming one of the diagnostic numbers but I don't know which one.
f-bu,
The file you uploaded here, I found in my book. The diagnostic signal details. Your list has DNG# 106 &107 where my book doesn't. My control has all zeros in #106. The information you uploaded for DNG#101, bits 0,1,2, and 3 are override signals. I confirmed this in my book. I also found in my book Parameter #1004 which are for OPG1 through OPG7. All of the descriptions for each of the OPG# have to do with actuating different buttons and switched on the software operator's panel.
anyone,
Is the software operator's panel the control panel?
OPG#4 is described like this:
1 Jog feed rate, override, and rapid traverse override switches are actuated with the operator's panel.
0 The above switches are not actuated with the software operator's panel.
I changed and tried several configurations in parameter #1004 and nothing appeared to change.
Again parameter #1004 is with all zeros and all of the features listed work except the feed overreide switch. Please not that OPG4 is set with a zero. This would tell me that the switches are not actuated on the software operator's panel.
So I am still stuck... Still looking for help.
