I just go my CNC router up and running. I have used the stepconf wizard to set up EMC2 and now i can jog all axes, and sometimes execute a g-code program.
Here comes the strange stuff; When I try to run the initial g-code program, the one that is there when you start EMC2 up everything works like a chram. But when i load the 3dpengu (1.st of the example files) it runs for a random time, usually just a second or two before is just stops. EMC2 says stopped in the lower left corner. I thougt this could be a case of interferance on the E-stop circutry so i disabled the E-stop in pin in stepconf. Still the same problem!?? Is there any place i can see what caused EMC2 to stop?
I can toggle machine power on again and continue for a random period of time.
My second little problem is that i get a error each time i home the axes. limit switch fault. In stepconf I've used the "Both Limit + Home X" should not that take care of the ignore limit when homing on limit switches? I also seems like it is when the axes is done homing that is does trip the limit switch again?
The axes moves in, trips the limit, moves out again and then two moore rapid mooves that trips the limitswitch?
edit: Figured out the homing problem! It is a case of axes home beeing in
the same place as the switch trips.
Home location 370
Table travel 0 to 370
Home switch location 370
Guess I'm ok if i change the Home location to 365.
regards Chris
