586,690 active members*
2,948 visitors online*
Results 1 to 3 of 3
    Jan 2009
    15
    Extrusion Help
    I am a small start-up looking for a source for aluminum tube extrusions 2" x 2" 6061 with a 0.125 outside corner radius. It seems like all the suppliers locally do not stock this item. I am in the position where manufacturing 1000 lbs. of tube stock is a little out of budget right now. Does any one know a supplier that would have this in stock? I could go for anything under 100 lbs.
    GW
    Have you looked at 8020 aluminum?
    http://stores.shop.ebay.com/8020-Inc...__W0QQ_armrsZ1
    Hope that helps.
    Please check out my CNC blog
    http://cncinside.com
    Feb 2009
    41
    Try Signature Aluminum out of PA. They do custom extrusions.
    www.signaturealuminum.com
    -coolantman
  1. aluminum extrusion
    By georgebarr in forum DIY CNC Router Table Machines
    Last Post: 05-14-2013, 09:03 AM
  2. extrusion software
    By amr_elsayed in forum Bending, Forging, Extrusion...
    Last Post: 02-26-2013, 05:37 PM
  3. DIY extrusion die
    By llilrex in forum Bending, Forging, Extrusion...
    Last Post: 09-29-2008, 09:12 AM
  4. Plastic extrusion
    By StarLoc in forum Moldmaking
    Last Post: 03-16-2008, 02:32 PM
  5. extrusion saw
    By jimglass in forum News Announcements
    Last Post: 12-14-2005, 12:36 PM
