586,105 active members*
3,324 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Help with BP Interact 412 Encoder Pinouts/Descriptions
Results 1 to 9 of 9
    May 2007
    100
    I have a BP Interact 412 that I am currently retrofitting. Does someone has the pinouts or pin descriptions for the Servo Encoders?
    This is what I have below: Servo Motor and Pins for the Servo
    This is what I need: A, ~A, B, ~B and Power Connections to the servo encoder
    Thanks in advance for any assistance.
    Joel
    May 2007
    100
    I was able to find the pinout for ERO115-XXX Encoders, source www.cncrotary.com
    I hope this will help someone,
    Joel
    Jul 2007
    23
    Have you been able to get.....
    Have you been able to get you machine running with german encoders? I am still undecided about using mine or changing out to something a little more simple.
    Do you have the mulitplier box as well?
    May 2007
    100
    The stock Heidenhain Encoders are Sine Analog. So they will not work with most modern drivers. Also, the resolution was only 0.00033/inch.
    I changed out the encoders with digital quadrature ones, not our resolution is 0.00025/inch.
    You can see the entire build on the Mach3 Forum:
    http://www.machsupport.com/forum/ind...c,13365.0.html
    Hope this helps,
    JH
    Nov 2006
    925
    What have you done with the ERO encoders you took off,JH?
    Mark.
    May 2007
    100
    The old encoders can't be just taken off, their integrated into housing. But if you looking for parts of the encoders like the lamp, encoder wheel, circuit board or the aperture housing, I have some of those parts left. If you looking for something specific, let me know.
    JH
    Nov 2006
    925
    Quote Originally Posted by JHCHOPPERS View Post
    JH
    The individual parts can still be removed from the motor.I just wondered if you wanted to sell the lot.I`m not interested in specific parts.
    Mark.
    May 2007
    100
    Mark,
    Just sent you a PM if your interested in some spares for your machine.
    JH
    Nov 2006
    925
    JH
    I have replied.
    Thank you.
    Mark.
  1. Anilam 1100M pinouts
    By actionman in forum Controller & Computer Solutions
    Last Post: 03-05-2013, 12:53 AM
  2. Fadal RS-232 wiring pinouts
    By Michael82 in forum DNC Problems and Solutions
    Last Post: 10-23-2008, 11:06 PM
  3. ladder descriptions
    By ktb100 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-28-2006, 02:04 AM
  4. Help W/Wiring Pinouts on Nema23 269 oz.in. Kit
    By InventorJohn in forum Xylotex
    Last Post: 12-29-2005, 05:14 AM
  5. Correct LPT pinouts???
    By rsecret in forum CNC Machine Related Electronics
    Last Post: 10-13-2005, 04:07 AM
