586,713 active members*
3,010 visitors online*
    Feb 2006
    8
    Slow axis speed
    Hi
    I have recently built a 5ft square 3 axis CNC router, incorporating a gantry, stepper motors, EMC, and trapezoidal lead screws. All works reasonably well except the fastest speed I can reach on the x and y axis is 15mm per second. This seems a little slow. Can anyone tell me what kind of speeds similar sixed machine run at.
    Aaron
    You're going to have to provide some info on about your machine. Motors, power supply, weight, screw lead.....
  1. Micro torque converter to slow router speed
    By technomage in forum DIY CNC Router Table Machines
    Last Post: 08-07-2013, 07:34 AM
  2. Slow Speed Stalling?
    By bigz1 in forum Stepper Motors / Drives
    Last Post: 04-20-2008, 08:15 PM
  3. Help. Slow speed
    By shamus13 in forum Mach Mill
    Last Post: 12-08-2007, 06:06 PM
  4. Slow down the pneumatic actuator speed
    By Syphonics in forum Mechanical Calculations/Engineering Design
    Last Post: 12-21-2006, 05:21 PM
  5. Cut speed is stuck at Slow????Mach 2
    By mwalach in forum Mach Mill
    Last Post: 08-24-2006, 12:58 PM
