M05--Will not stop spindle from coasting to a stop. Machine is 3 months old. Any suggestions?
There is No Spindle brake in the Tormach so don't expect it to stop on a dime...you may need to adjust your deceleration rate on the VFD...read your manual
Thanks for the comeback. I would appreciate if you could tell me where I adjust the deceleration rate at. I cannot find anything in my manual. Thanks again.
http://www.tormach.com/document_libr...alibration.pdf
http://www.tormach.com/document_libr...gnAnalysis.pdf
you most likely have the series 2...the first link is for the series 1 machine you may need to call Tormach for more info.
I have a series 1 machine so I can't help you much here
If you have the series II here is a link for the "Getting Started" and "Advanced User" manuals for the Commander SK drive.
http://www.controltechniques.com/CTc...downloads.aspx
om -
Assuming you have a Series II machine, your manual (Table 5.3 on page 9-51) tells how to read the spindle drive "trips" on the spindle controller's display. Page 9-52 tells how to use the "M" button on the controller.
Since the controller simply dumps current into a braking resistor to stop the motor, then the resistor is possibly blown or disconnected. In that case, the controller will show "tr-OU" on the display.
Regards,
- Just Gary
