586,060 active members*
4,328 visitors online*
Results 1 to 9 of 9
    Feb 2009
    Mazak T32-3 Alarm 015 System Malfunction
    Hi guys,
    I've got a Mazak SQT15MS T32-3. When I turned it on today the keys at the operation panel were not working and a few minutes later Alarm 15 "System Malfunction" came up on screen. I restarted several times but the same result. I looked in the electrical cabinet and when it's started initially all the drives LED's appear correct (i.e.: X/B Drive :Flashes between d1 & d4 . Z Drive:d2. Sub Spindle Drive: r0 . Main spindle Drive r0.) but after a few minutes the main spindle drive LEDs go blank, showing nothing (that's when the Alarm comes up on screen).
    In the Alarm manual it says the following :
    Alarm 015 System Malfunction.
    Cause: An error occurred in data transmission between MCP and the Amp when the power is turned on.
    Action: Check Amplifier for :
    Improper connections.
    Improper power connections.
    So what I'm wondering is what is the MCP and what Amp are they on about ?
    Any advice please ? Is this a sign of some problem anyone is familiar with ? What's my best course of action ?
    Mar 2008
    33
    I've run into a similar problem. If you don't mind me asking, what did it take to get your machine back up and running?
    Thank you,
    Gary
    Aug 2009
    71
    Need Help! Mazak T32-3 Alarm 015 System Malfunction
    Is the spindle drive FR-SF? If so, check the Yellow LED on the SF-PW (power supply) on top side of the Spindle Drive.
    If it is off, there are several reasons,
    1) Any of feedback cables grounded.
    2) Faulty SF-PW.
    3) Faulty SF-CA card.
    Regards,
    Girish
    Mar 2008
    33
    The drive is a FR-SF and a yellow and green led are lit at the top of the drive. The drive gives an AL 36 alarm with is listed as a Transfer Error.
    Thank you for your help,
    Gary
    Aug 2009
    71
    Problem could be the CAM11 cable or the MCP/CPU (MC1xxx) card on CNC from which this cable comes out.
    If CAM11 cable is ok, need to check
    1) Memory clear & reload from backup
    2) Replace MCP/CPU card & check.
    May be MELDAS service engineer required for this.
    Regards,
    Girish
    Mar 2008
    33
    I really do appreciate you taking time to respond and the information you provided. We will check these items out and will probably have to call Mitsubishi.
    Thank you,
    Gary
    Mar 2009
    109
    If the LED's go out after a few minutes with the machine just sitting idle, it sounds like it's just a weak SF-PW.
    May 2011
    4
    Mazatrol 640t 15 system malfunction
    Hello There
    We do have the same error on Mazatrol 640t 15 system malfunction so i was wondering did you got your machine working back to normal.
    On our machine it started with RTC battery error and will not boot to win95 so replaced the battery then did boot but at last it stuck on this error all though the all functions works eg spindle spins, tool changing but can not get reed of this error.
    Please do let me know if you do got your sorted.
    Thank you
    May 2011
    4
    Hello There
    I have the same error as you had (15 system malfunction) is your machine is up and running if so could you please let me know what you have done to get reed of that error.
    Look forward to hear from you.
    Thank you
    Raj
  1. Mazak H-500 Alarm
    By newguy81 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-17-2013, 06:50 PM
  2. PMC system alarm
    By dalvinder in forum DNC Problems and Solutions
    Last Post: 09-06-2007, 02:28 AM
  3. Mazak VTC-160 A servo malfunction
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 05:19 AM
  4. System Alarm # 3
    By tedh in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-25-2005, 11:12 PM
  5. Mazak L Alarm
    By SFA in forum DNC Problems and Solutions
    Last Post: 05-26-2005, 06:52 AM
