586,655 active members*
3,127 visitors online*
IndustryArena Forum > CAM Software > Mastercam > W axis on Mastercam
    Feb 2006
    28
    W axis on Mastercam
    Anyone out there programming a horizontal boring mill with fanuc control?
    I've used X3 for programming 3 axis vmc and 4 axis boring mill. I need to program a hbm that has a W axis (spindle extension).
    How do I setup a machine/control definition for this type of machine so mastercam will recognize another axis as well as another G43 offset for the w axis.
    any help would be appreciated.
    I tried adding a linear axis in the machine definition manager and designating it as the W axis. That worked OK, but I am not sure how you would differentiate between Z axis moves (table in and out) and W axis moves (spindle in and out) Try posting up on emastercam somebody there may have already figured this out
    Feb 2006
    28
    I tried doing that as well, but like you said, it really doesn't know the difference
    between the two axis. I ended up making up an .mmd for a horizontal mill and modifying one of the posts that I already use. This does the job for now and it takes me a few minutes to change some values from z to w. I will look some more into this and try the other forum as well.
    Thank you for your help degmc.
    Sep 2006
    10
    Hi
    I have right post for you, only problem is I made this post for V9 mastercam,
    And I if you still need it email me [email protected]
    I would appreciate if you have heindenhein iTNC 530 posts in conversational format for v9 or X2
    gasho
    p.s.
    pozdrav zemljak
  1. 5 Axis programmer - Mastercam
    By Rotor_nut01 in forum Australia, New Zealand Club House
    Last Post: 01-27-2009, 12:42 PM
  2. Mastercam x c-axis problem
    By Mike68 in forum Mastercam
    Last Post: 11-20-2008, 02:21 PM
  3. mastercam postprocessor 5 axis
    By pgman68 in forum Post Processor Files
    Last Post: 05-07-2008, 02:26 AM
  4. 4th Axis Toolpath with mastercam
    By rcrabb in forum DIY CNC Router Table Machines
    Last Post: 01-07-2007, 03:41 AM
