586,652 active members*
2,731 visitors online*
    Mar 2005
    18
    Question Dahlgren 2516i Serial Port Setup?
    I posted this in the engraving forum, but thought I might try here, too!
    I'm attempting to set up a PC to talk with a Dahlgren 2516i. This particular Dahlgren doesn't have a USB, just a serial port (COM1).
    I'm using the Engravelab Expert 5.0 rev. 6.4, and the manual - while detailed about certain obvious things, is remarkably vague when it comes to important things.
    There is no manual for the 2516i, and the online manual I've managed to find is (again) remarkably vague about connection. It does tell me what temperature the room has to be at. And the differences between the spindles (neither of which look exactly like the one I've got).
    So my emergency question is: What the heck to are the settings?
    I'm looking for:
    Bits per second (currently at 9600)
    Data bits (currently 8)
    Parity (currently NONE)
    Stop bits (currently 1)
    Flow control (which is currently NONE; handshake makes the computer wait for DSR, NONE and X-on/x-off both give me a "Serial overrun" error on the Dahlgren).
    Any help would most certainly be appreciated!
    Your pal,
    Meat.
    May 2011
    need halp dahlgren 300 i have program superpro. i bayet a old 300 wich meny program i need help to start the machin i can nat dos . if you can help me
    Aug 2014
    15
    Re: Dahlgren 2516i Serial Port Setup?
    Do you still have the System 300? Do you still need help? See the other http://www.cnczone.com/forums/engrav...-software.html post for my knowledge of these engraving machines.
    If the System 300 for sale let me know. wayne at engravers dot net
  1. serial port
    By willfly4food in forum Gecko Drives
    Last Post: 05-22-2012, 05:16 PM
  2. USB TO SERIAL PORT HELP
    By jeffm in forum Controller & Computer Solutions
    Last Post: 01-28-2012, 01:57 AM
  3. can i use a usb port instead of serial?
    By tuf045 in forum Bulltear Industries Support Forum
    Last Post: 04-10-2010, 04:05 PM
  4. Dahlgren 2516i Serial Port Setup?
    By meat in forum Engraving Machines
    Last Post: 02-13-2009, 10:09 PM
  5. USB to serial port
    By stampman in forum DNC Problems and Solutions
    Last Post: 12-30-2006, 08:17 PM
