586,317 active members*
3,394 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Machine Definition
    Mar 2007
    114
    Machine Definition
    I am new to Camworks and have managed to define my machines in the tech database. However when i am in camworks and try to define the machines from the feature tree these added machines do not appear, only the default ones are there. Any help would be appreciated
    richard
    RRb Machining
    Apr 2005
    88
    I would make sure that the Tech DB you are modifying is linked to your CAMWorks. I have seen this happen when there are a couple different DBs. Go to the DB that you have changed and click on the maintenance button and re-link the tech db.
  1. Machine Definition Doesn't Change Code?
    By PrecisionD in forum Mastercam
    Last Post: 02-13-2011, 08:31 PM
  2. Set Up Definition
    By SPEEDRE in forum Bridgeport / Hardinge Mills
    Last Post: 02-22-2008, 02:46 AM
  3. What's the definition of an end mill?
    By Swiss in forum MetalWork Discussion
    Last Post: 08-01-2007, 04:32 AM
  4. MC V9 Casting Stock Definition
    By CAMCRASH in forum Mastercam
    Last Post: 10-12-2006, 09:52 PM
  5. Tool definition
    By David Da Costa in forum Mini Lathe
    Last Post: 07-04-2006, 04:48 PM
