586,119 active members*
3,583 visitors online*
Results 1 to 8 of 8
    Apr 2006
    22
    V22 Facing ?'s
    I have a part that is "u" shaped that I need to take about .03 off the top of. I want my cutter path to follow the "u" shape of the part. When i use the "mill 2 axis facing" command, it just wants to mill straight across the part as if it were square. Is there another way to do this, or am i just doing something wrong?
    Bink
    Dec 2008
    4548
    When you say U shaped do you mean it is concave in the Z direction? Or are you wanting the facing to be constrained by a boudry instead of just do a full facing patern around an object
    Apr 2006
    22
    part is flat on the table. yeah, i just want the face op to be restricted to the u shape boundary. was thinking i could draw a box around my part and say that my u shape is a pocket, maybe trick it that way.....
    Mar 2005
    368
    Here's 2 ways:
    First is a Pocket op with zero depth.
    Second is Profile with zero depth and large stock remaining number (multi passes) and right angle leadin long enough to plunge down off of part.
    I recall reading that boundaries in 2d facing was in the works for later release.
    moldmker
    Apr 2006
    22
    Thanks, the second way you described is what i am looking for. what did you use in each of the fields to get that tool path, i am pluggin in something wrong. havent been able to quite get it.
    Jul 2008
    90
    Hi Bink, I have bobcad V22. It sounds like you don't want to face it at all. Being you want to take .03 off the top of a shape sounds more like a "pocket" operation. Have you thought about doing it like this yet?
    Mar 2005
    368
    Quote Originally Posted by bink View Post
    These values are based on the leg of the U being 1" wide.
    I think Bobcad kinda screwed up the naming of the Stock remaining and Spring passes, but that's my opinion. If you take the Stock and divide by Spring pass, that's your approx. stepover amount.
    The neg. Side allowance lets the tool overlap the edge of the part.
    Play around with the numbers and recompute and you'll see how they work.
    Only use the Rough tool, leave the Finish tool at 0 dia..
    Good luck,
    moldmker
    Apr 2006
    22
    Thanks!
  1. cylinder facing
    By pp-TG in forum MetalWork Discussion
    Last Post: 01-30-2009, 03:53 PM
  2. Facing Copper Help
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 10-31-2008, 11:42 PM
  3. Facing operation
    By mikeh78 in forum BobCad-Cam
    Last Post: 07-14-2008, 11:08 PM
  4. Facing around a boss
    By macona in forum Mastercam
    Last Post: 06-07-2008, 08:40 AM
  5. Facing
    By impact in forum MetalWork Discussion
    Last Post: 02-23-2006, 03:24 AM
