Well as stated before I could hear my X axes creeping but giving no DRO movement, and now all three axes are creeping simultaneously. Now scratching my head with both hands instead of one any ideas, anyone.
I don't know how safe your set-up is...But If you power up the machine only, no computer ,no Mach , does it still do it? (Dont attempt if you know the machine will run away uncontrollable with no controls on it! I dont want you to get hurt or damage the machine)
BUT..Then you can rule out anything computer or software related, that is...
If you are getting power leakage to the drives before the "automation" or control takes over the machine.
When you say no movement is seen on the DRO, Do you mean the MACH screen, or do you have a seperate DRO on the system?
The fact that you can hear/see the x axis moving, (when no control is asking it to move), is probably the reason why you see no movement on the DRO. If you had encoders you would see the movement coming back to the DRO.
If you are also seeing all the axis creep now when no control command is given, I would look at your power set-up/ gains ect... you also mentioned that you are missing steps during a run, which could mean the controls are having a hard time positioning the axis due to the fact that the drive(s) is not set-up 100% or the power going to the drives is too "Dirty".
Hope this makes sense?
I am out in Georgetown...where are you in Ontario?
menomana
Hello Shooter,for starters I,m out in Whitby east of T.O... Yes the machine does move without the aid of P.C. or Mach3..., axes were moving in the plus side, whether that means much....The DRO values we talked about that were not seen was with Mach not a seperate controller.I supose that the power setup and gains controls would be directly on the drives,is this correct?What would be the reason the power to the drives would be dirty? This is the part of the CNC world I,m weakest at.The drives came from www.durhamrobotics.com. You can see them on his site.Hear is something that happened a long time ago, my power supply in he begining did not have a fuse on the power side and my bridge rectofier came loose due to heat and I ended up melting some wires.The toroidal transformer had a slight bit of sheathing come off but it seamed fine,none of the windings took a hit. I had the bridge recto replaced ,and a fuse put in since then.I,m wondering if there was some underlying damage that was not caught because since then I have also tried a different BOB with a changed chip for noise.I got a feeling I may need to have someone make me up a new controler/power supply. Would it hurt to put in a seperate PPort?Thanks for your help ,much appreciated.
Hi Corrie,
I had a quick look at the link you provided. I dont see any provisions for gain/voltage adjustments on these drives. He does however have a jumper to limit/set the amount of current on the "polar drive" he sells. Is that the drive you purchased?
The "Critical motion" drive he offers is listed as un-available due to "Performace test" not meeting his criteria...Did you buy one of these possibly before they realised they had issues?
I dont see any way of tuning the drives unless he provides you with documentation after purchase re-garding how to adjust gains...ect???
I would suspect ( as an armchair mechanic here) that if you are seeing movement with just the machine power on...no pc, no MACH 3 turned on, and you had the power supply problem in the past, that you might have damaged part of the drive? Or if you have one of his "Critical motion" drives, maybe it is possible they have un-covered a problem with these drives??
Assuming the power supply was rebuit ok, and is putting out the proper rated power to the drive, then, there is potential that you have a bad/poor connection somewhere (power supply or on drive)
The only other thing I can conjur up at the moment is that the drive can't handle the "rush in" current when first turned on...In which case you could argue the drive needs protection against this, In the way of proper power supply, and if that is the case then again, the drive has potentially been damaged from past "un-protected" use.
He say's there is a low power standby mode, perhaps this area of the drive is not functioning correctly.
It is hard to say for sure without being in front of the machine. Have you e-mailed him and asked if they have seen this before on their drives?
menomana
Hey shooter, I must say you are quick on the replies.I don,t have the critical motion drives, I have the polar drives.He has been over a few times to have a look into the problem but is not sure himself.He put a scope on the controller to see if and where there was any noise in the system.We ran it in sherline mode half step just to see anthing inbetween the pulses because not much was showing up according to him, this all well above my head.
