586,103 active members*
3,353 visitors online*
    Oct 2004
    38
    No X axis movement- how to troubleshoot?
    I'm having some problems with a Gecko driver, and in the process of horsing around inside my controller I may have caused more problems.
    Right now, I need to know how to troubleshoot Mach 3 outputs to be sure that my control box is getting step and direction voltages at the control box input. As I look at the settings in Mach 3, I don't think they are changed and they seem to be correct. Mach seems to be running the X axis when I jog, showing motion on the DROs. But the controller won't move the motors.
    In the controller, the fuses are OK, and the Geckos have power LEDs on. The Y and Z axis are OK. Just the X axis is not working.
    If I can determine that Mach3 is sending the correct voltages, I can start looking in the control box.
    Thanks for any help.
    Wayne C
    Feb 2009
    48
    in your port address settings you have three boxes in the far right box theres a chech mark get rid of the check mark it should work i had the same problem took me a month to figure out
    Measure the X dir pin voltage while jogging back and forth. It should toggle between 0V and 5V, depending on direction.
  1. New SX3 - Axis Movement
    By meyermicro in forum Syil Products
    Last Post: 05-27-2008, 02:36 PM
  2. Axis Movement
    By KARD in forum CamSoft Products
    Last Post: 05-21-2008, 11:29 AM
  3. No Z-Axis Movement
    By btcoutermash in forum Bridgeport / Hardinge Mills
    Last Post: 08-12-2007, 08:42 PM
  4. Axis Movement
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 12-17-2004, 08:33 PM
  5. How To; troubleshoot an Axis problem on Bridgeport BOSS
    By inthedark in forum Bridgeport / Hardinge Mills
    Last Post: 03-25-2004, 02:35 PM
