586,655 active members*
3,792 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > DNC Problems and Solutions > Fanuc O-MD controller-"Magazine not oriented” message
    Feb 2009
    We are having some problems with the ATC on a 2000 Amera Seiki VAS 3M with a Fanuc O-MD controller. When we received the machine, it was missing 3 pots in the tool changing magazine. While running a program with a couple of tool changes, the machine was trying to put a tool in a place where there was no pot. I hit the E-stop while the arm was at the spindle. I was able to rotate the arm back to a zero position and clear the ATC error, but I am now getting a “Magazine not oriented” message. If I try to rotate the magazine, the machine doesn’t pull up the pot before it tries to rotate the magazine, which causes a bind. We have turned the machine on and off a couple of times, turned the air on and off a couple of times, the sensors seem to be functioning properly, and we have rotated the magazine back and forth to a couple of different positions to try to clear the message, but to no avail. I have read through what machine manual says to do, but it still doesn’t seem to be working right.
    Mar 2008
    169
    And the manual says...
    Feb 2009
    If you know a solution to this I would greatly appriciate it? The manual that I have is missing a number of pages and is old and unreadable.
    Feb 2009
    Intermitent Sensor output
    I have a few years ago the same problem with a mazak cnc and the problem are: the position sensor works intermitent, not allways send the signal but, the light of the sensor allways working, check with a multimeter the voltaje output of the sensor, some times the output is bad but the light of the sensor works good.
    Feb 2009
    Thanks Jav40 I'll check that.
  1. BOSS8 "+Z OVERFLOW" error message
    By jonny in forum Bridgeport / Hardinge Mills
    Last Post: 05-29-2008, 10:12 AM
  2. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2007, 09:35 PM
  3. Fanuc 11M alarm message
    By Moparmatty in forum DNC Problems and Solutions
    Last Post: 08-07-2007, 03:32 AM
  4. Fanuc 11m error message. improper number of axis
    By kmcmillen571 in forum DNC Problems and Solutions
    Last Post: 04-02-2007, 01:14 AM
