586,570 active members*
3,699 visitors online*
Thread: OKUMA-HOWA
    Mar 2006
    OKUMA-HOWA
    I have a 1984 Okuma-Howa VMC with a Fanuc M10 Control.
    I have "EMG" code/prompt on the CRT indicating "Reset JOG". I guess
    one of my students manually sent the machine home in "JOG"
    instead of "Machine Reference". Iv'e tried resettting at the contol panel,
    that didn't work. I've looked through the limited Operations/Programming/Maintenance manual to see how
    or where to rest the the "JOG" control. I can't locate the alarm code
    anywhere. Can I just locate and reset the relay on the "Z" axis board or is there more to it than that?
    Bruce
    May 2006
    179
    Is the machine on a limit switch? If so, you will find an O/T release switch. Hold it in, then turn the mpg to move it away from it. If no luck there, remove the cover, grab the ballscrew and manually turn it. Also, check and see if the estop is pushed in.... you never know
    Good luck !!
  1. Okuma-Howa 3VA manual(s)
    By gbowne1 in forum Okuma
    Last Post: 02-05-2021, 10:03 PM
  2. Okuma-Howa HL-20
    By howd in forum Okuma
    Last Post: 07-16-2014, 02:55 PM
  3. Okuma Howa 2sp-30H part #
    By OKUMA Tech in forum Okuma
    Last Post: 11-14-2008, 09:19 PM
  4. Difference between a Okuma & Okuma Howa
    By 69owb in forum Okuma
    Last Post: 06-04-2008, 05:51 PM
  5. need help okuma howa lathe
    By mike10 in forum CNC Tooling
    Last Post: 09-17-2006, 02:10 AM
