586,121 active members*
3,190 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > My two 4 axis Haas post processors (VF2)
Results 1 to 8 of 8
    Feb 2009
    Question My two 4 axis Haas post processors (VF2)
    Here are the 2 post processors that I got for my haas mill. Both are not working as expected with the A axis. The problem that I have is that in "mill mode" the 4 axis button does not activate. Because of this I cant machine a surface using the A axis simultaneously with other axis (a helix for example). I tried making a new post processor from the haas template but i cant mange to make it work (the same problem) even if I do declare or activate a 4 axis during the new post creation.
    Does anybody knows what to do? anyone with a haas post that works with 4 axis simultaneously?
    Thanks in advance!
    Attached Files Attached Files
    May 2004
    142
    hey man... i got your private message..
    someone at edgecam gave me a post processor.. and it still doesnt work worth a damn for simultanious 4 axis machining.... but it does work pretty good if you are machining pockets using unwrapped geometry..and even then its more like 3 plus 1 machining.
    i feel your pain ... i have probably built a dozen or so post processors from the given templates...somtimes it works..but most of the time it doesnt. i have even went as far as using a five axis template and removing "everything b"...
    i have wanted to highspeed machine helical gear shaped parts or wing type parts with a ball end mill fixed and the a rotating under it..instead of indexing and 3d contouring and indexing and so on.... i just dont think that edgecam is capable of this type of milling... if so ..i havnt seen it. i will pm you my email addy...there are a bunch of things you can do as work arounds that i have became quite good at ,that i will share.... i dont get on this forum to often because its slower than hell...
    DONT MIND MY SPELLING ... IM JUST A MASHINIST
    Jun 2008
    125
    Smile 4 axis simultaneous
    Guys,
    What format are you wanting on the code?
    I'm getting this for 4th ax sim ....
    N80 T02 M01
    N90 S2000 M3 M41 M7
    N100 G0 X75.0 Y0.0 B0.0 A0.0
    N110 G43 Z55.0 H01 M7
    N120 X81.367 A8.58 F1293.1
    N130 G1 X80.414 Z54.445 A10.86
    N140 X78.693 Z53.889 A12.43
    N150 X76.546 Z53.334 A13.0
    N160 X74.398 Z52.778 A12.44
    N170 X72.674 Z52.223 A10.87
    N180 X71.715 Z51.668 A8.59
    N190 X71.712 Z51.112 A6.07
    N200 X72.666 Z50.557 A3.79
    N210 X74.386 Z50.002 A2.22
    Whereas yours is different with the G107 and wrap height.
    A couple of other things as well
    1) have you got the licence for rotary?
    2) in edgecam have you switched to rotary mode
    When creating new posts in the future always choose the adaptive templates. In milling choose either the adaptive-mill-iso or the adaptive-mill-tnc
    Hope this helps
    Mar 2006
    1013
    If you dont have a button (it's greyed out), it means you dont have that feature. The Edgecam menus are dynamic, so only the functions of your software will have active buttons. If your sure your should have that feature, I'd call my dealer and ask him.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Jul 2008
    20
    Talking
    Calling the dealer is a great suggestion as they probably also have thousands of customers using EdgeCAM 4 Axis and Haas machines.
    May 2004
    142
    is there any way to adjust the angular increment in the post pro.the feed rate looks like its set up for inverse time feed... and on haas i thought that every feed move has to be accompanied by a (inverse time) feedrate.
    i used the 5 axis cycle to try to machine a wing shaped part...and it looks perfect in edgcam and the simulator... it just dosnt work so hot on the machine...it posted way to much code for the machine to read... and i have a haas superspeed with the look ahead algorithym deal...!!
    i wish there was a 4 axis cycle... lol
    Jan 2009
    52
    I had trouble with the rotary not working, called tech support for as much help as they were, all the wanted to do was sell me the next level higher for synchronized 4and 5 axies milling, and we already have the advanced production kit.
    In the end he really didnt help me and i still dont know how to make the y axies lock up and all the movements made by the rotatry for all jobs but I did have some luck on some jobs when i made a rapid move to y0 ,turned on rotary mode, and in the machine roughing i put the stock type to none,then all movments were made by the rotary
    Also you mught have to right click on the sock feature on the left of the screen and click "primary rotary axies"
    Jun 2003
    73
    they weren't trying to "upsell" you. in edgecam you cannot machine a solid model or a surface with the 4 axis sim. milling. you can machine wireframe geometry in rotary, If oyu have a model to machine, you can extract edges with the geometry from edges command and then use a piece of the shareware/freeware called power unwrap. then you're standard cycles which are included in advanced production.
    Mike W.
  1. how do I set my post processors
    By Alan0166 in forum BobCad-Cam
    Last Post: 06-04-2015, 08:15 AM
  2. post processors
    By littlerob in forum Okuma
    Last Post: 12-06-2008, 06:26 PM
  3. Haas 5 axis Post...
    By thirumalkumarn in forum Mastercam
    Last Post: 09-04-2008, 04:40 AM
  4. Need Post for Haas 3-axis Mill
    By GisMo in forum FeatureCAM CAD/CAM
    Last Post: 09-20-2006, 10:26 PM
  5. Haas Post Processors
    By broken arrow in forum Haas Mills
    Last Post: 06-21-2006, 07:10 PM
