Hi Guys,
Don't forget to serialize the build.
I don't think you will get 10" sec out of 80 watts for 3/16 leather, more like 5" sec but someone with an 80 watter may be able to clarify this.
You could always put the laser tube behind the X axis rail as there would be room for it with a 4' table with maybe a bit hanging out and it would solve your divergence problems as the beam would only be going for about 5' max but you may have problems with vibration in the tube if you don't have really smooth rails and fast stops and starts may be a problem also (you could experiment with the acceleration curves.
I also keep asking people to try out photocopier mirrors for wattage's bigger than mine at 30 watt but no one seems to try it and they are free from office scrap so I would give it a go and save $80 if it works.
You really only need a good quality pond pump for the water cooling too. (weipro ?)
I couldn't find out if the stepper drives you want were micro stepping ones, and you will definitely want that, as it makes everything smoother and quieter at 1/8 micro steps.
Try Econobelt for your belt and pulley needs.
You have 1 item missing and it is the heart of the whole machine and ties everything together....... The software !
The cheapest you will get is about $1300 or you could use Mach3 at $150 as others have done and not have engraving capabilities. I could never get it to work very well but that's a refection on me and not the software.
Best of luck.
Rich.
I am not completely useless.......I can always serve as a BAD example.
