586,598 active members*
3,585 visitors online*
IndustryArena Forum > Material Technology > Metallurgy > 304 CRES Stainless Steel
Results 1 to 10 of 10
    Feb 2009
    6
    What does CRES stand for and is there Different Grades for this material? How well does it machine?
    Apr 2005
    713
    CRES stands for Corrosion Resistant. What you have is regular old 304.
    Feb 2009
    6
    Thank you for that info. This is very helpful.
    Dec 2006
    242
    It machines ok, but much slower than 1018. Drilling with split point cobalt at 30 sfm is what I would recommend. Milling with cobalt roughers flooded (65 sfm) and TiALN coated carbide finishers dry (250sfm). Rubbing work hardens the piece. Never dwell and you should be good.
    If you can, use 304L; it has higher machinability. If no further specs are called out (ASTM, etc.) any commercial grade can be used. 304 is Austenitic (non-magnetic). End milling & turning speeds are 60-110 SFPM HSS, 220-360 SFPM carbide (from the Machining Data Handbook). It work-hardens easily so don't dwell or make skin passes. It welds easily also.
    Oct 2005
    2392
    Great info, thanks all.
    How does 303 compare to 304 for lathe machining, assuming that both are readily available?
    Jun 2009
    135
    303 is 2 to 5 times EASIER to machine. Given a choice I think any experienced machinist would go with 303.
    Nov 2005
    1468
    An old saying: "303 she's for me, 304 she's a whore"
    Jul 2011
    I have a material call out that only says "CRES per Matl Spec 6863". Anyone know what that spec is? Would that make the CRES 301, 303, 304?
    Thanks, Tim
    Oct 2011
    But 304 looks so lovely when done right
  1. 303 vs. 304 stainless steel
    By pearldiver in forum MetalWork Discussion
    Last Post: 02-06-2020, 08:45 AM
  2. SFM 17-4 Stainless Steel
    By Stowe Figler in forum MetalWork Discussion
    Last Post: 04-12-2012, 04:37 PM
  3. Stainless or non stainless steel ACME screws?
    By amanmazleigh in forum Linear and Rotary Motion
    Last Post: 07-07-2011, 05:00 AM
  4. Stainless steel
    By larry53 in forum MetalWork Discussion
    Last Post: 04-23-2007, 05:32 AM
  5. Steel or Stainless
    By tool_man in forum Casting Metals
    Last Post: 10-29-2006, 12:46 PM
