586,068 active members*
3,706 visitors online*
    Feb 2009
    Help getting started
    I'm a long-time user of 3D modelling software and I decided to try Alibre Design because I am working on an electronics product design.
    I'm having some trouble getting started. The first task I have to do is make models of all the parts. I decided to start with the main board, since it should be easy. It was easy enough to make a rectangle and extrude it and then and the mounting holes. Now I'm trying to add some simple shapes to represent the chipset and parts on the board. I created another rectangle and extruded it, but I can't figure out how to move it around. How do you move different pieces (features?) around in the parts editor?
    Or should I be going about this a different way? I just thought it made sense to put everything on this board into one part because we're not going to chage it. What will change is how we put it together with the peripherals and housing.
    Make a new sketch of the different parts (1 sketch per piece), and dimension the sketch to give it a relationship to the main board. Then just change the dimensions to move the parts.
    Or make it a separate assembly.
    Jan 2006
    4396
    Quote Originally Posted by jays View Post
    Do exactly as Ger21 says but before you create your sketches create 3 new planes 1 for each like this in the screen shot. These planes can be moved which allows you to move your part. Just be careful because this can also cause problems. The planes are XY Plane 2, YZ Plane2, ZX Plane 2. I relabeled them to avoid confusion. Also create a Part Drawing Template so you don't have to do this to every part drawing.
    Your best be is to create each sketch approximately where you want it. Dimension the sketch. Then you can Drag or Dimension the position. Perform your Extrude Boss, Extrude Cut etc.
    When working with Assemblies you can import each part one at a time and apply constraints to position your parts. It's a lot of work but until a software is created that reads your mind it has to be done manually.
    The best thing you can do is watch the Tutorials. Even though they might seem primitive there are lots of tips and tricks that will help you down the road.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
  1. Getting started...
    By fordbroncoxlt in forum MetalWork Discussion
    Last Post: 02-01-2008, 08:20 PM
  2. help getting started
    By shootingarts in forum Mentors & Apprentice Locator
    Last Post: 11-18-2007, 04:30 PM
  3. getting started
    By richaevans in forum CNC Wood Router Project Log
    Last Post: 08-21-2006, 04:34 PM
  4. getting started on the Z
    By craftech in forum DIY CNC Router Table Machines
    Last Post: 01-10-2005, 12:52 AM
