586,070 active members*
3,442 visitors online*
    May 2009
    1332
    How to Select Microstep
    My 4 stepper motors are NEMA 23, 2 Phase, 1.8 deg, 270 oz.in, 2.8A.
    The attached picture shows my choices to select Microstep Resolution. Which one will be the best for my motors?
    Nicolas
    Re: How to Select Microstep
    You can try to run micro step 8 (1600) or 10 (2000) for most of application
    https://www.automationtechnologiesin...r-motor-driver
    Nov 2013
    4373
    microstepping beyond half stepping anyway, does not really improve resolution, although its nice to think it does......it does not work in practice.
    Where microstepping is important is smoothness of motion. Astronomers were the first to use microstepping because they needed smoother motion from their
    steppers so the telescopes didn't vibrate.
    The downside to microsteppeing is that it requires an ever increasing pulse rate from your motion controller and/or breakout board.
    The pulse rate to have a stepper rotate 10 revs/second or 600rpm with eight microstepps per full step, ie 1600 pulse per rev is:
    PulseRate=10 x 1600
    =16kHz
    The pulse rate to have a stepper rotate 10 revs/second or 600rpm with 128 microstepps per full step, ie 25600 pulse per rev is:
    PulseRate=10 x 25600
    =256kHz
    If you have a really fast motion controller then the later solution is fine....but most of us have slower motion controls and do not wish to have such demanding high frequencies so the first
    solution is adopted.
    As it turns out most people select between 4 microsteps per fullstep to 16 microsteps per fullstep to get the advantage of smooth motion without going off the deep end and having
    a really high pulse rate.
    Craig
    May 2009
    1332
    Many thanks to both
    Nicolas
  1. Microstep Machine
    By haroutkhaloian in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 03-15-2015, 07:36 PM
  2. microstep settings, what is it, what does it do?
    By greenjeens in forum Stepper Motors / Drives
    Last Post: 12-08-2012, 01:57 AM
  3. New microstep driver 6A
    By smartgsm in forum Open Source Controller Boards
    Last Post: 02-12-2011, 10:29 PM
  4. microstep clarification
    By stirling in forum Gecko Drives
    Last Post: 09-11-2010, 06:57 PM
  5. New microstep test
    By nhatson.elec in forum Stepper Motors / Drives
    Last Post: 05-28-2009, 06:45 AM
