586,103 active members*
3,446 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Arc tangent to an Arc
    Nov 2007
    11
    I have Mastercam X mr2. Is there a way to tangent an arc with an arc. I am trying to make a spline lines into arcs. Can anyone help
    Jan 2008
    123
    In the pull down menu for create/arc/tangent the last button on the right tangent to 2 entities If that's not what your looking for sometimes you have to create some construction geo to get it to do what you want then delete the extra lines,arcs etc when you done
    post a file if you need more help
    Mar 2006
    1013
    A Fillet is an arc tangent. Pick Fillet, enter your radius and pick the 2 other arcs.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Jan 2008
    123
    I didn't think of that.....thanks Mike
    Dec 2008
    3109
    Use " Simplify " on your splines before creating or fitting arcs, some of the work will be automatic
    Edit--> Simplify
  1. Line tangent through point
    By mastercamguru in forum Mastercam
    Last Post: 12-07-2008, 01:26 AM
  2. Drawing a tangent to two curves
    By accellodyne in forum Mastercam
    Last Post: 12-02-2008, 06:52 PM
  3. line tangent from...
    By Castle1 in forum Rhino 3D
    Last Post: 09-21-2007, 02:08 AM
  4. two radii with a common tangent
    By ParadiseIsle in forum Mechanical Calculations/Engineering Design
    Last Post: 04-23-2006, 01:18 AM
  5. tangent point
    By bob in windsor in forum MetalWork Discussion
    Last Post: 12-23-2005, 10:05 PM
