586,106 active members*
3,031 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Need Some Guidance in Choosing Components for a 251 Build
    Sep 2003
    1469
    Question Need Some Guidance in Choosing Components for a 251 Build
    I have earned some cash that doesn’t have any home earmarks on it and am ready to add some parts to the G251’s that I have been sitting since September of 2008.
    I want to build a dual drive screw machine about 3’x 4’ I have some nice linear bearings and ball screw, the ball screw is not a precision ground but will see how it works out. Photo below.
    I would be cutting MDF, Plywood, Hardwoods, and occasionally some aluminum.
    I am lucky to have my homemade fixed gantry machine to do the job of making its brother, so this will be a much easier build than the first one. It was a big learning curve for me.
    Could you recommend Steppers, Breakout Board, and Power Supply for the 251’s. I have red your comments about the Vexta PK268-03A (Oriental Motor Company) and it is out of my range.
    I kind of would like to buy them all from one supplier if possible just for the ease of dealing with one supplier when it came time for troubleshooting and not have one supplier blame the other and my in the middle, but separate suppliers is not a show stopper.
    Sep 2003
    1469
    Question
    I guess the question is too broad because I didn't get any replies.
    I have listed some parts below and want to get a conformation on the best way to go for my application as described above.
    I would prefer to stick with one supplier but if there is a dramatic difference I will split the suppliers.
    CNC4PC
    BOB: There are two any advantage over the Kelinginc?
    CG11 FOR GECKOS
    http://www.cnc4pc.com/Store/osc/prod...products_id=46
    C11T
    http://www.cnc4pc.com/Store/osc/prod...roducts_id=181
    KELINGINC
    STEPPERS:
    425
    http://www.kelinginc.net/KL23H286-20-08B.pdf
    BOB:
    C11
    http://www.kelinginc.net/C11Manual.pdf
    POWER SUPPLY: There are 2 that are close to the 50V limit for the G251, which one would be the better.
    KL-350-48 48V/7.3A
    110V/230V $59.95
    KL-300-48 48V/5A 110V
    $49.95 out of stock
  1. Components to build your own mill ?
    By castiron in forum Open Source CNC Machine Designs
    Last Post: 02-26-2008, 06:13 AM
  2. Looking for a little guidance!
    By jayty97 in forum DIY CNC Router Table Machines
    Last Post: 02-15-2007, 03:43 AM
  3. choosing servo components
    By bshapiro in forum Servo Motors / Drives
    Last Post: 01-17-2007, 07:19 PM
  4. I need a little guidance please....
    By Steve F in forum Servo Motors / Drives
    Last Post: 05-15-2006, 07:16 AM
  5. Need some CNC guidance
    By seafire in forum Waterjet General Topics
    Last Post: 11-16-2005, 05:07 AM
