586,075 active members*
3,741 visitors online*
    Feb 2009
    12
    cutting metals with a wood machine
    hello there,
    I am new to this site and am looking to build a cnc machine. I have a few questions. could a well built machine designed for wood be used for aluminum or brass? would it just be a matter of slower speeds and adjusted spindle speed. or would it need to be 'beefed' up to make a more sturdy machine like a bigger spindle motor, or using metal for the framing of the machine? has anyone here done any light milling of aluminum or brass with thier homebuilt wood machine??
    thanks in advance, I think this site is great. Ideas being shared with like minded individuals is such a great advancement for humankind...
    mac
    Oct 2007
    153
    yes; within reason- there really isn't much of a difference; I have a sherline desktop mill at home it's quite small and is mostly aluminum so it lacks the dead-weight that is generally regarded as being condusive to a more effective machine- however with the reduction in horsepower rigidty and dead weight it is still capable of macghining harder materials albiet at the expense of overall speed and aggressive material removal rates.
    Jan 2006
    106
    Yea, most machines are capable of machining those softer metals, just have to make sure you dont run it too fast, keep collant on it, and use the correct bit and spindle speed.
  1. Cutting "odd" metals
    By Scratch in forum Waterjet General Topics
    Last Post: 11-18-2007, 04:57 PM
  2. Plasma cutting metals other than steel.
    By LeeWay in forum Waterjet General Topics
    Last Post: 04-05-2007, 06:07 AM
  3. Speeds for cutting metals relating to pulley size?
    By ZipSnipe in forum Mechanical Calculations/Engineering Design
    Last Post: 06-16-2006, 02:11 AM
  4. Where can I find Good CNC Wood Cutting machine for Car parts size ?
    By Calico in forum DIY CNC Router Table Machines
    Last Post: 02-28-2005, 06:36 AM
