586,117 active members*
3,541 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Arrow 1000 spindle trouble
    Nov 2008
    9
    the arrow 1000 mill I'm working on has got me baffled. When it goes to change from tool 4 to tool 5 the z axis moves up from the part but not up to tool change position and then sets there with the spindle running. It will have no alarm and will sit there running for infinity. I cleaned and reseated all the connectors to the spindle amp and the problem went away for 2 days, then reoccured.
    Help
    Ray
    Jan 2008
    48
    Is it just when it changes from tool 4 to 5 or any tool change? If you shut off the spindle with an M9 before the M6 will it change tools? Does it only have this problem in one program or any program?
    Nov 2008
    9
    Only from tool 4 to 5. This is the only program it has been running. The program looks good. you can stop the spindle and do a tool change. Then it may run 1-50 parts before the problem reappears.
    Jan 2008
    48
    Are you running sub programs with an endless loop? I have had strange things happen when running loops. It has always been programming problems that were not easy to find.
    I really have no other ideas, that is really strange.
  1. Acramatic 2100 Arrow 1000 need help
    By griz-shop in forum Cincinnati CNC
    Last Post: 12-06-2008, 07:49 PM
  2. parameters for cincinnati arrow 1000 (1998)
    By aherrc in forum DNC Problems and Solutions
    Last Post: 04-25-2008, 08:04 PM
  3. trouble to align cincinnati arrow 1000 (1998)
    By aherrc in forum Servo Motors / Drives
    Last Post: 03-08-2008, 12:16 AM
  4. trouble with alignment of a cincinnati arrow 1000 (1998)
    By aherrc in forum Uncategorised MetalWorking Machines
    Last Post: 03-07-2008, 11:20 PM
