586,121 active members*
3,681 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > Where to find Shell mill / Face mill arbor for taig
Results 1 to 6 of 6
    May 2007
    86
    Does anyone know where I could find a shell mill / face mill arbor for my taig?
    Or does everyone just stick with using a fly cutter for surface finish?
    Frank
    Oct 2008
    55
    There was one once But when I found it the link didn't work any longer.
    http://www.cartertools.com/spill.html
    Marty
    Jul 2007
    1602
    DeArmond Tool http://www.positiveflow.com/taigacc.htm has had one in the past though I don't see them listed there anymore.
    You might call or email them to see if they still carry them or can point you to their source.
    Apr 2007
    83
    No one knows anyone that carries a face/shell mill for the Taig? Can anyone point out a shell mill of Taig size, that would work if I had to make an adapter?
    I really need one of these. I need to surface large blocks of steel, aluminum, and 360 brass. Can anyone think of something I could use???
    May 2007
    86
    I believe that if you were to make an adapter you could use one of these shell mills: Enco Shell Mill
    Oct 2009
    80
    Taig er16 1/2" end mill holder
    Shars 1/2" shank shell mill arbor
    http://www.shars.com/products/view/7...ll_APKT_Insert
    or
    http://www.shars.com/products/view/7...ll_RPMT_Insert
    or
    anything on ebay/etc. that uses the same 3/4" mounting method.
    Don't know how long this ends up being. You could cut the arbor, or combine the first two items and make them yourself I suppose.
  1. Using a shell mill
    By mrk in forum MetalWork Discussion
    Last Post: 08-11-2007, 02:59 PM
  2. Face/Shell Mill Arbor
    By Zumba in forum Uncategorised MetalWorking Machines
    Last Post: 05-21-2006, 04:01 AM
  3. Where can I find a good clamping kit for a TAIG mill?
    By Smertrios in forum Taig Mills / Lathes
    Last Post: 03-25-2006, 04:27 AM
  4. Recommendation for Shell arbor and mill
    By kdoney in forum MetalWork Discussion
    Last Post: 03-18-2006, 10:37 PM
  5. Need an R8 Shell Mill Arbor
    By CoolHand in forum Uncategorised MetalWorking Machines
    Last Post: 02-03-2004, 03:02 AM
