Hi Guys
I have a couple of simple washer type dies i am making a different size for 30mm o/d 6mm i/d , unusual bit is the the Monel 400 40micron mesh its pressing out !(cutting clearance next to nothing!!)
My prob is not quite sure how to dowel thru with drills and reamers etc as the tooling is hardened and the die set is soft , so ill dowel one side and tighten the other side when located on each other but then im not sure??
Thanks for any help
Cheers Kev :cheers:
