586,119 active members*
3,512 visitors online*
    Jan 2008
    20
    Home made linear bearings,
    i am thinking of making my own linear bearings for a CNC router i am making with my students. Would it work if i used a accurate 1" reamer and reamed out a piece of brass to run on a 1" piece of CR steel?
    thank you
    Jan 2006
    738
    Try bronze bushings (some available at home depot even) polished CR.
    Feb 2008
    586
    Reaming is iffy, depending on your setup. I'd rather bore to just under, then hone to fit (shaft may measure 1", but may be out of round.
  1. Home made ATC
    By pstockley in forum Uncategorised MetalWorking Machines
    Last Post: 11-09-2009, 11:12 PM
  2. skate bearings versus linear bearings
    By paul langwade in forum Linear and Rotary Motion
    Last Post: 05-29-2006, 04:06 PM
  3. Linear Motors for a home made machine?
    By NEATman in forum Linear and Rotary Motion
    Last Post: 05-12-2006, 02:30 PM
  4. Bearings for home made linear
    By Alaskan in forum DIY CNC Router Table Machines
    Last Post: 08-14-2005, 07:09 PM
  5. Home made CNC mill (and some products made by it)
    By gcamlibel in forum DIY CNC Router Table Machines
    Last Post: 04-05-2004, 11:54 PM
