586,065 active members*
4,264 visitors online*
    Oct 2004
    38
    Computer power supplies
    Hi
    Has anyone ever used a computer power supply for powering stepper motors they have a 12v dc output. I was thinking to have three in series giving 36v dc and the recommended voltage for my motors is 36-42. Also could anyone tell me if these are switch mode power supplies and also tell me exactly what this means. Any help is greatly appreciated.
    Lee
    24221
    Quote Originally Posted by flannman
    Hi
    Lee
    The problem you would have in series-ing them is that you would have to make sure the DC common was not connected to chassis ground, in other words you would have to isolate the commons, which could get tricky, also the current rating for the 12v supply is not very high.
    They are switchmode power supplies which mean they use higher frequency switching than the incoming ac frequency of 60Hz or 50Hz, this allows the use of compact, light, switching transformers, without the need of large step-down transformers at mains frequency.
    Al
    Albert E.
    Oct 2003
    593
    I'm currently using the +5V supply from a PC PSU to power my steppers and Al's right, they're pretty crap for this application.
    Regards Terry.....
    http://www.terry-is.f2s.com
    Oct 2004
    38
    I will give that idea a miss
    Thanks for the help. I thought they would be perfect but was obviously wrong. I will have look into a better idea.
    Lee
  1. Connecting Two Power Supplies
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 03-19-2005, 01:03 AM
  2. Question about power supplies
    By dowling177 in forum CNC Machine Related Electronics
    Last Post: 01-28-2005, 02:01 PM
  3. 2 12volt power supplies in series
    By jderou in forum CNC Machine Related Electronics
    Last Post: 09-03-2004, 02:04 PM
  4. These power supplies useful?
    By jlawren6 in forum CNC Machine Related Electronics
    Last Post: 08-26-2004, 02:19 AM
  5. Lowering Voltage on Power Supplies?
    By DaSigntist in forum CNC Machine Related Electronics
    Last Post: 01-17-2004, 09:31 AM
