586,497 active members*
1,448 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > YAPSC:10V : The glue between Step/dir and +/-10V servo amp
Page 12 of 13 210111213
Results 221 to 240 of 259
  1. #221
    Mar 2011
    Re: YAPSC:10V : The glue between Step/dir and +/-10V servo amp
    Do you still have these boards (YAPSC:10V),, If so I need them.
    Please call me at 610-984-3012 Joe Sells
  2. #222
    Nov 2012
    boa noite
    Tambem estou interessado nas pci
    Voçe consegui alguma?
  3. #223
    Oct 2009
    5
    Got some boards from Andy and need help.
    My setup is PC <> YAPSC:10V <> PAC SCI SC-903 <> PAC SCI R33 motor.
    - YAPSC fw: 2.0.7, tuning tool YT 1.3.4.
    - About SP-903 configuration don't know nothing (no interface card), tried step/dir control, no response, then tried analog cmd and motor started to spin, after that found YAPSC.
    - Wired everything, first test and got some problems, motor oscillates cw - ccw see videos (sorry for poor quality, old phone)
    video1
    video2
    - after several seconds YAPSC goes to maxerror, and drive goes to fault Nr.4 (Attachment 253240).
    - P set to -0,22 (tried from -0,001 to -1 same result [- because with + i get maxerror fault at startup]), I and D 0.
    - encoder gives good feedback, tried to rotate shaft with disconected motor power and YTT reads about 8200 steps/rev.
    - also find out that driver SC-903 response just when YAPSC output is higher than +5V.
    Would be great to hear any suggestions, since i'm new to servo systems, but not new to automation ant process control.
    Saulius
  4. #224
    30
    Hi Lucas
    Are you still selling your boards?
    I have CNC VMC with Simodrive 611 and Sinumerik 820M. Would like to change Sinumerik to another Chinese cnc controller (GSK or Adtech) but would like to keep Simodrive drives with motors.(x,y,z, toolchanger, spindle - all of them use simodrive).
    What do you think, are these boards stable to use on production machine?
    Best regards,
    Oskars
  5. #225
    Feb 2014
    4
    Hi lucas
    I am using pulse to analog - one of my friend prepared for me. It works fine but only problem is reverse direction. I need convertor which change direction of signals as per mach direction output
    Please guide me for this
    Sent from my iPhone
  6. #226
    Jan 2007
    93
    If anyone interested for UHU servo controller with analog (+/-10Volt ) output visit Custom Machine Design
    I have designed UHU servo controler witch can control analog ( velocity,torque ) linear servo amplifiers.
    Also , avaible only boards to assemble. 4 PCB avaible. Price 8.50 eur .
    If interested, PM .
  7. #227
    Apr 2008
    20
    Does anyone have and seal these boards (YAPSC:10V),, If so I need them.
    Please write on my e-mail [email protected]
    Asek
  8. #228
    15362
    Quote Originally Posted by Aleksasek View Post
    Asek
    I have ( 1 ) that has never been used, has programing key as well
    Mactec54
  9. #229
    Jan 2007
    93
    I have 3 PCB's for sale . Price is 8 eur /pcb.
    Payment : Paypal
    If interested, contact me.
  10. #230
    Nov 2011
    4
    Hello!
    I have board YAPSC 10V.
    How can I use the index of the encoder for Homing? (Linuxcnc)
    Is it possible ?
    What are the options?
  11. #231
    Oct 2006
    32
    visky: "I have 3 PCB's for sale . Price is 8 eur /pcb.
    Payment : Paypal"
    3 x 8 = 24 eura = 1L dobrog viskija :cheers:
  12. #232
    Aug 2015
    142
    Hi , is there somme nc files for mach 3 , because i strugle with gerber files for some times , and i ca't get them to end , or a cam program to handle that gerber project.
  13. #233
    Oct 2009
    5
    I have several boards for sale. If anyone need it, please PM.
  14. #234
    Apr 2008
    20
    Quote Originally Posted by nkp View Post
    Hello!
    Is it possible ?
    Hi nkp
    Do you have homing with INDEX? You make something?
    Just asking, it's very interesting.
    Alex
  15. #235
    Sep 2015
    Does anybody have any of these boards available to purchase or is this project no longer going? Cheers
  16. #236
    Jul 2016
    I have 10 PCB's, and lack the time to build. I need some one to build x3 of them for me to test, and you can have the rest.
    Private message me if interested.
  17. #237
    Sep 2016
    31
    Hello Lucas
    Your PM settings won't allow me contact you directly. Just wondering if you ever got any further with your YAPSC - type converter.
    Quote Originally Posted by lucas View Post
    There"s some further testing needed, I will publish schematics etc.. when everything works as it should .
    This design is compatible with Max's PCB (connector pinout) but has some changes and improvements, well I consider these as improvements :-)
    - a real RS422 receiver is used for the encoder: 26LS32, capable of differential and single ended encoders and with proper line termination for high speed.
    - works on a single supply: 8 to 24Vdc, + and - 12V are generated by a DC-DC converter.
    - encoder can be connected with a DB9 or screw terminals.
    - stp/dir/enable inputs have optocouplers and can be connected using a PMinmo style flatcable or screw terminals
    - The progkey is compatible, this or Max's version can be used on both designs
    I have 9 PCB"s left now for some beta-testers.
    One thing might change: the drive error input and Yapsc error output, this is very basic now and might need improvement to support more models of analog drives.
    Please send me a PM if you"re interested.
  18. #238
    Quote Originally Posted by Tripet View Post
    Hello Lucas
    David
    Lucas has not been involved with the YAPSC for some years due to time constraints.
    He walked away from the project at around the time I was looking at them that's why I looked into getting the boards printed myself.
    Andy
    Sent from my SM-G920F using Tapatalk
  19. #239
    Sep 2016
    31
    Quote Originally Posted by audioandy1762 View Post
    David
    Andy
    Thanks Andy.
    Looks like the YAPSC project is dead then - what a shame.
    David
  20. #240
    Nov 2006
    4
    I think I've got 3 or 4 YAPSC boards sitting around somewhere, just populated with the uController. If anyone would like them, let me know.
  1. Gecko PID step motor servo
    By Mariss Freimanis in forum Gecko Drives
    Last Post: 03-26-2015, 08:54 AM
  2. step motor or servo
    By dcutler35 in forum Uncategorised MetalWorking Machines
    Last Post: 06-09-2012, 06:18 PM
  3. Servo step multiplier
    By JerryFlyGuy in forum Servo Motors / Drives
    Last Post: 05-15-2007, 08:20 PM
  4. Units Per Step For Servo
    By bgolash in forum Mach Software (ArtSoft software)
    Last Post: 02-14-2006, 08:46 PM
  5. Servo and Step motors
    By Dre361224 in forum CNC Machine Related Electronics
    Last Post: 06-09-2005, 02:33 AM
