586,052 active members*
4,055 visitors online*
    Nov 2007
    24
    Different depths w/ Ace Convertor
    I'm using A9CAD, which is 2D, and copy several dxf designs into a single file.
    When I use Ace Converter the resulting shapes in g-code are at different depths.
    I made sure that everything is on the same layer but they always come out with a different Z-axis value.
    Anyone have any ideas?
    Can you post the .dxf?
    Jan 2012
    9
    Program Dsp deleted
    program dsp handel
    hi all
    i have machine cns " maxima " with dsp command the problem that i lose the program
    the all for DSP are delete , now when i put the usb result is , only scren is light and the red led is on
    you can see the photo of my dsp
    please some one can help me
    i ask my china supplier but until now i don't receive any information
    hope find a solution for this problem
    thanks and best regards
  1. Incremental Z Depths In Drilling
    By Litnin in forum Mastercam
    Last Post: 03-01-2012, 04:28 PM
  2. Cutting slots at various Z depths ??
    By jwknow in forum Haas Mills
    Last Post: 01-22-2009, 09:02 PM
  3. Setting depths in Lazycam
    By kenealym in forum Uncategorised CAM Discussion
    Last Post: 07-07-2008, 06:12 AM
  4. Z-finish Depths
    By jamesr in forum Surfcam
    Last Post: 12-20-2006, 07:07 PM
  5. Depths of cut on a lathe
    By M@T in forum Uncategorised CAM Discussion
    Last Post: 01-30-2004, 04:40 PM
