586,110 active members*
3,366 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinatti Arrow 1000 Down For the Count
    Nov 2007
    4
    Question Cincinatti Arrow 1000 Down For the Count
    Hi Guys,
    I'm at the Oregon Institute of Tech. and have a Cinci With a Acro 2100 control and on start-up the other day, it got through the initial screens, but when it started to load windows, the monitor went black and I got just a cluster of white pixels on the black screen. When I turn it off, it goes through the 30 seconds normal time, then shuts off. I expect it is the op sys or the hard drive. Any suggestions on how to start. We changed out the motherboard batteries and I'm worried about backing up all tables/params before moving ahead. Thanks for any suggestions. DC: [email protected]
    Jan 2008
    48
    Have you eliminated the monitor as being the problem?
    Apr 2004
    353
    Did you have both batteries out at the same time? We did that once a few years ago and it gave us big trouble.
    If you want to rule out the monitor - I think you can hook one up externally to the control. Make sure to unplug the current one.
    Oct 2009
    28
    I just had this problem and it turned out to be the real time board. Hope this helps.
  1. Cincinatti Milacron Arrow 1000 Tooling Error
    By david_culler in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-22-2015, 01:10 AM
  2. Acramatic 2100 Arrow 1000 need help
    By griz-shop in forum Cincinnati CNC
    Last Post: 12-06-2008, 07:49 PM
  3. cincinatti milacron arrow 750
    By kevmor in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-11-2008, 04:10 PM
  4. Cincinatti Arrow Service Needed
    By mlkaiser99 in forum DNC Problems and Solutions
    Last Post: 09-14-2007, 07:42 PM
