Offer Cutting plotter
High Quality: it has special electronic route design to make the electric mother-board more stable. It can work under the voltage of 100-250V.
High Precision: Adopt international modern line-path and alloy paper feeding stalks; it can cut the little character of 5mm smoothly.
High Speed: Adopt CPU of 16 bits and advanced digital motor, it can support a high cutting speed of 720mm/s.
Cutting Thoroughly: Adjustable bit pressure which has the maximum of 400g, and real cutting soft fall, can cut easily no matter thick or thin.
Cutting Language: The cutting plotter support the format dictate of DM/PL and HP/GL. it can support various popular software like AUTOCAD, CorelDraw etc.
New Functions: Big screen LCD and Repeat Cutting function can make you operate conveniently.
MODEL DL-800 DL-1120 DL-1360
Max.paper width 800mm 1120 mm 1360 mm
Max.engraving width 720mm 1040mm 1220mm
Max.engraving speed 25-500mm/s
Pressure 25-400G
Resolution 0.0254mm/step
Repeat resolution 0.01mm
Power 160-260V 150-240V 110-230V
Format HPGL/DMPL
Interface RS-232/CENTRONICS
LCD Yes
Size 1040×300×320 1340×300×320 1580×300×320
Weight 18kg 24kg 40kg
Nanjing Qianding Technology Co., Ltd is an advanced enterprise specializing in the research, development, production and sales of CNC engravers
