586,036 active members*
4,343 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Homebrew spindle challenges/not a machinist
Results 1 to 7 of 7
    Jun 2006
    44
    I have a DC motor that I will try out as a spindle motor. It comes from a treadmill, about 1HP.
    Getting from a threaded shaft to a ball mill- I have no idea what I need next.
    For drills, a Jacob chuck seems to make sense.
    I see a lot of collet types, 5C and ER20 having made an impression.
    I have never watched a machinist change a milling tool, so don't know what happens.
    I am attracted to the Tormach TTS system, because of the "Consistent and accurate Z axis tool holding", so OK fine.
    For hours, I looked through MSC for collet chucks, and found nothing with a "drawbar", and any reasonably priced pneumatic chuck for auto tool changing, though that's the direction I'm leaning.
    I'd like to reduce the weight of the Z-axis. as much as possible, so I don't want a spindle flywheel, or chuck adapter plates, or 18" drawbars and handles, and yet which way should I go?
    Should I treat this like a vertical lathe, and get the 5C collet from The Little Machine Shop?
    Your opinions are invited and will be considered.
    Thanks for the help.
    Dec 2006
    947
    Wow, what you've asked is a lot for one conversation. Let's start off with what are you going to be using for a spindle, you can't use a motor for a spindle, it turns the spindle providing power but is not a spindle itself?
    Apr 2005
    1778
    Quote Originally Posted by Cartierusm View Post
    Strictly speaking this is not true. If the motor spindle is large enough diameter, it can be machined to use as a spindle. However, it requires something with adequate precision and freedom from runout. A few people have successfully created spindles from servo motors.
    Alan
    Dec 2006
    947
    Duh..brain freeze I was thinking regular motor. But still it's quite a lot of precision work.
    Jun 2006
    44
    yep, we are on the same page.
    I need someone knowledgeable to help me by pointing out what is missing between the motor and the milling bit. I plan to use electronics or belt pulleys to regulate the spindle speed.
    It is the OTHER STUFF that I am unfamiliar with. For example. I know that the milling bit goes in the right sized collet, and that for a quick change to another bit, it is standard practice to take out the last bit/collet and put in the next bit, already mounted in the right sized collet.
    What I don't know is, how is the collet held firmly, with little tir? With a collet chuck, I've guessed, which probably extends to open when you yank the drawbar or press a switch. Right there, I am lost. I see lots of bit holders, usually R8, but I am going for a low weight setup, so I want opinions on ER20 and so on.
    Also if anyone has direct experience with building a spindle from scratch, then they probably know what to buy and from where. So that is the kind of info I am looking for.
    I don't want to just buy a whole spindle setup, I can't afford it. So I have to try to build my own, and THERE'S where I need good experienced advice.
    Aug 2008
    1166
    Bill,
    Do some reading first:
    http://www.cnczone.com/forums/showthread.php?t=10695
    http://www.cnczone.com/forums/showthread.php?t=41200
    http://www.cnczone.com/forums/showthread.php?t=32609
    http://www.5bears.com/cnc.htm
    This should answer some of your questions. That said, if you're not a machinist and don't have machine tools available to you, I would not try to build a spindle. I'd buy one.
    Jun 2006
    44
    Thanks!
    Thanks for the reading list! That was a generous and helpful thing to do.
    I did read each one. The new spindle design and the 5Bears links were useful, while a link in the middle sent me to YouTube, where I happily watched chips flying from DIY machines. Thanks! I'm re-infected with CNC zeal now...
    I still haven't been convinced to use huge and chunky R8 gear to rotate a cutter. I noticed the 5 Bear.com builder was upgrading a Sherline, so I'll have to study his approach more.
    Thanks again!
    Aloha
    Bill
  1. My Homebrew
    By Danka in forum Community Club House
    Last Post: 12-31-2007, 06:59 PM
  2. Looking for CNC machinist/manual machinist in detroit metro area
    By Runner4404spd in forum Employment Opportunity
    Last Post: 11-12-2007, 07:11 PM
  3. Re-cycling a Issoku Precision Spindle into my homebrew CNC machine
    By hwhacker in forum Uncategorised MetalWorking Machines
    Last Post: 08-08-2005, 05:19 AM
  4. Spindle motor control for homebrew cncmill
    By stuart76 in forum CNC Machine Related Electronics
    Last Post: 05-21-2005, 03:10 PM
  5. Homebrew driver - HELP!
    By chuckknigh in forum CNC Machine Related Electronics
    Last Post: 11-11-2004, 04:20 AM
