586,080 active members*
3,702 visitors online*
Results 1 to 2 of 2
    Jul 2005
    9
    maximum feed rate question
    When my machine is running a program (program run window) it maxes out at 60 units/min no matter how I have the feed rate set in the G code. When I click the over ride button I can speed the cut up quite a bit. Do I have a setting goofy or what? I would like to be able to run this at the faster speeds without hitting the over ride.
    Thank you.
    Jul 2005
    9
    I messed around with the motor tuning and figured it out.
  1. Whats Maximum baud rate on an OM-D
    By meadowtech in forum Fanuc
    Last Post: 02-21-2009, 06:17 AM
  2. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
  3. Feed rate question
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 10-30-2004, 07:00 PM
  4. Another feed rate, cut depth question
    By nervis1 in forum Uncategorised MetalWorking Machines
    Last Post: 02-10-2004, 06:56 AM
  5. Master 5 feed rate question
    By IIRONMANN in forum Mach Software (ArtSoft software)
    Last Post: 12-29-2003, 08:25 PM
