587,035 active members*
3,177 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > 4th Axis Parallel Roughing
    Aug 2003
    318
    I have a 3d stl model I need to cut using only the 4th axis tool
    paths. Due to its size I cannot use 3 axis roughing. I can create a
    4th Axis Parallel Finishing toolpath but I can't set the Roughing. How
    do I do that. Have 24" dia part need a .5" stepdown .2 stepover on the
    rough and a .02 step over on the finish.
    All the docs mention 4th Axis Parallel Roughing, but I don't see how
    to make it work.
    Thanks in advance.
    Jun 2007
    6
    4th Axis Roughing option
    I have a 3d stl model and I want to cut it with the help of 4th axis but in mastercam there is no option for 4th axis roughing and in finish cut there is no option to change the angle of the cut.
    Jun 2003
    2103
    Hi Donny,
    If it were Madcam I could help you out next week....I think. Wait that almost sounds like Popeye's sidekick Wimpy! "If you will give me a hamburger today I will gladly pay you next Tuesday".....or something like that!
    How complicated a part is it?
    Mike
    Quote Originally Posted by whiteriver View Post
    to make it work.
    Thanks in advance.
    No greater love can a man have than this, that he give his life for a friend.
  1. 4020 4th axis problems
    By little bubba in forum Fadal
    Last Post: 06-14-2005, 03:08 AM
  2. 4th Axis
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 03-19-2005, 04:25 PM
  3. Can 4th axis do offaxis undercuts ?
    By lesd in forum Visual Mill
    Last Post: 12-17-2004, 01:27 PM
  4. 4th axis machining
    By senor J. in forum Visual Mill
    Last Post: 10-22-2004, 09:10 PM
  5. Reverse thinking on a 4th axis
    By whiteriver in forum Visual Mill
    Last Post: 03-03-2004, 06:38 AM
