586,080 active members*
3,637 visitors online*
Results 1 to 14 of 14
    Feb 2004
    6
    Question Dyna mechtronics DM3000
    Picked up this DM3000 cnc lathe for a steal, but i can't find any programs to run it. So far all i get is its to old. But there has to be something out there? So if anyone can lead me in the right direction i would be much apprecaited. Looking for cad-cam w/post. Thanks
    Jul 2003
    148
    If it came with manuals, see if their is a generic format it accepts. Fadal, Haas etc.
    Feb 2004
    6
    Checked the manuals all i could find was ASCII string.
    Jul 2003
    148
    Just to clarify, programs....To control the machine or to output to the machine? Also all the programs I've run across are ASCII string. Only differnce is how their are formated.
    Feb 2004
    6
    Output to the machine
    4826
    Is their website no longer current?
    If nothing else, start with a Fanuc post and see what it does.
    http://www.dynamechtronics.com/product.html
    Jul 2003
    148
    Usally most programs that output code have a post processor which tells the program such as Turn Master or what not how to format the file and output it. What ever CAM package your using you should be able to edit this post processor or create a new one for your machine.
    The manual you have should help you with creating the post processor.
    Feb 2004
    6
    After more digging and a few phone calls i found out this machine does not use G codes. But there might be a retro fit from Ah-ha. So this is why i got a great deal on this machine.
    Apr 2004
    38
    I have a Old Dyna 4400 mill with the same basic control. It is not G&M code compatable. It uses what Dyna calls dynalan . MasterCam has a post for this mill so maybe they have a post for the lathe, my sugestion, retrofit!!! If you are use to G&M codes then the dynalan is a nightmare. I do think that Dyna is still giving some tech support i.e. manual purchase if you call. I hope that this helps as I went thought the same thing with my mill.
    Cheers
    Jim Walthall
    Mar 2005
    5
    dm3000
    I own a 3000 and a 3000H. They have been great machines. Have owned the 3000 for 18 years and the 3000H for 13 years. BUT, yesterday had a (Mistake) crash with the X axis. Now the little stepper is making a strange noise and won't move the crossslide smoothly. I believe the stepper is shot and am looking for another one. Please help!!
    Jul 2003
    148
    Crash
    Not familurew with that machine. I have a prolight.
    If you can, disconnect the stepper/servo from the machine. Then tell the machine to step that axis. If the stepper still makes funny noises with no load then yeah you need a new stepper.
    If not then turn the lead screw to the table and see if that is hard to move or gives you problems.
    Let us know what you find out.
    Nov 2005
    I realize I'm jumping into this one pretty late, but...
    I have a Dyna 3000 that I use BobCad on. Their post processor (which they put together for me) does great. I can turn any shapes that I want, though I'm sticking with the built-in programs for threading because they are easy to understand. BobCad is going for a couple of hundred bucks, much cheaper than retrofitting new controllers.
    May 2008
    Smile dyna 3000 loading program from pc to dynamyte 3000
    if you need help e-mailme please
    I can help
    [email protected]
    May 2004
    22
    retrofit dyna 3000
    Any body retrofit a dyna 3000 lathe. Thanks Dan
  1. Dyna Mechtronics cnc Knee Mill need help with control
    By wisp in forum Knee Vertical Mills
    Last Post: 01-08-2021, 05:20 PM
  2. Dyna Mini CNC
    By topazx2 in forum Benchtop Machines
    Last Post: 04-30-2013, 12:56 AM
  3. Dyna 4400 pst help
    By JWWalthall in forum Post Processors for MC
    Last Post: 12-15-2010, 12:38 PM
  4. Dyna Myte 4400 (or other model) owners/users
    By mmedina in forum Uncategorised MetalWorking Machines
    Last Post: 04-01-2010, 04:22 PM
  5. Ebay# 3855421933, FRAUD DYNA MYTE MILL
    By davidponte in forum Community Club House
    Last Post: 07-01-2005, 02:09 PM
