586,069 active members*
3,484 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > Designing a quick change tool holder.
Results 1 to 6 of 6
    Nov 2008
    113
    Does anyone have any detailed drawing's of the Taig Headstock? I'm thinking about designing a QTH for the Taig mill. So far I've been thinking about designing something that would use Tormach style tool holders. So I'd probably need some sort of draw-bar system. Anyone have any thoughts? I know High Tech system's has a QTH for the Taig but I've heard mixed reviews, and its quite expensive.
    Jun 2008
    1082
    I'm not sure if Nick Carter created this model or if he's just hosting the file. One way or another it's pretty darn good.
    http://www.cartertools.com/crookmll.zip
    Twingy has also created a very nice looking Taig model, but so far as I know he has not released it, neither for sale nor for free. Check out his progress over here...
    http://www.cnczone.com/forums/showthread.php?t=70697
    Nov 2008
    113
    So I threw together a quick sketch of what I've been thinking of... No dimensions have really been decided yet. The Collet holder is 1.75" in diameter with the 0.75" threads to mount on to the ER16 spindle. The holder is 2" long. The tool holder while in the holder is 1.25" long. So that puts the entire assembly at 3.25" + tool -- This is really long....
    The draw bar is a 3/8" bar with 1" of 1/4"-20 threads at one end. The collet doesn't really have any numbers it was just sketched to fit inside the holder.
    The actual tool holder is a clone of a tormach basically, except with a 0.5" shank instead of 0.75" (its basically just smaller). The holder shown would except 0.375" shanked tools.
    Attached Thumbnails Attached Thumbnails Quick1.jpg   Quick2.jpg   Quick4.jpg   Quick5.jpg
    Jan 2007
    525
    Any update on this?
    Tormach PCNC 1100, SprutCAM, Alibre CAD
    Nov 2008
    113
    Quote Originally Posted by tikka308 View Post
    Any update on this?
    A little bit, was just thinking about this a few minutes ago since I have the spindle off. Measured it out well and have a decent model of the spindle going in SW.
    Thinking about revising the previous idea bit. All I need to do is create a reference plane. I think I can turn a piece steel that'll thread on to the current collet threads. Then, I need to make a custom collet, basically a 3/8" er-16 collet with a pull stud at the far end. Then just need to make draw bar with finger grips, or this can be one solid unit with the draw bar screwing in to the custom collets. Then its just belview washers and air cylinders.
    [Edit]
    Been looking around, can't seem to find "ER16 Blanks" or emergency collets. Little leary about trying to make an actual collet, I have never seen anyone actually manage to accurately turn a taper/slit the collet and come up with anything usable.
    [/Edit]
    Aug 2007
    558
    Smile
    Hi guys,
    Have you seen this thread: http://www.cnczone.com/forums/showthread.php?t=80662 ? Around post No. 3 Herbert shows a very nice looking pneumatic tool change modification to a standard Sherline spindle which may be interesting and relevant to your project (or may be no use at all...)
    Best regards,
    Jason
  1. A2Z CNC Quick Change Tool Post
    By Metaltinker in forum MetalWork Discussion
    Last Post: 12-06-2008, 07:55 AM
  2. Quick change tool post
    By mak in forum Shopmaster/Shoptask
    Last Post: 03-07-2008, 07:00 PM
  3. Replies: 4
    Last Post: 11-30-2007, 12:24 AM
  4. Quick tool change
    By Biggermens in forum Community Club House
    Last Post: 02-02-2006, 06:36 AM
  5. Quick change bit holder
    By Laff Riot in forum DNC Problems and Solutions
    Last Post: 04-17-2003, 05:48 AM
