586,115 active members*
3,397 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CNC (Mill / Lathe) Control Software (NC) > can some one show me what a facing program looks like for a Hass Lathe.
Results 1 to 14 of 14
    Apr 2008
    23
    Question can some one show me what a facing program looks like for a Hass Lathe.
    iam jujst starting out on one and if i can get any help its appreciated.
    also a turning program too .. what it would look like.
    Any stock size is fine ,, i want to see how to do it in a canned cycle
    Sep 2006
    48
    Try going to
    http://www.haascnc.com/training/Misc...20on%20Web.pdf
    and download the free program generator. It allows you to quickly generate the canned cycles and the code to turn the part.
    Let us know if you need more help.
    Stu
    Sep 2006
    11
    h
    Sep 2006
    11
    Haas OR Hass lathe program?
    Are you programming a Haas machine or a Hass machine?, you should be as specific as possible, as there may be subtle differences between these machines, and the NC code may not work properly.
    Sep 2008
    8
    here's the thing. I am telling you right now I don't claim to be an expert in long hand programming however I am about to receive my A.A.S. degree in machining tech and my emphasis is in CNC programming and operating. From personal experience I have found as a newbie in the CNC world it is far easier to program a facing cut long hand than it is to do in a canned cycle, only because, how many passes do you need to make for a facing operation? one, two usually...I.E.
    ( PREPARATORY COMMANDS GO HERE)
    G00 X1.5 Z-.010
    G01 X-.005 ( FIRST PASS)
    G00 Z.1
    X1.5
    Z-.020
    G01 X-.005 (SECOND PASS)
    And so on and so on. this is just for me an easier way of building and reading a program. because at my place of work and at school we do not have issues with information storage.
    I hope this info helps you, and I did not miss the point. thanks, joe
    Apr 2008
    23
    I went to web site but when i click on link to down load it doesnt work .. would any one possibly have this ? allready ?/ that can send m a e mail of it ?? i also called the company 800 phone number AND THEY SAID THEY COULDNT HELP
    Sep 2008
    8
    try CNCsimulator. I think the web address is www.CNCsimulator.com it has a basic simulation program you can use to do basic verification programming. howeeer if you are serious about verifying your stuff you can buy cimco edit5 with the lathe package thats what we use at work and at school
    Jul 2005
    12177
    As it says at the top this program faces and chamfers the end of a piece of stock. If you copy this and load it into a Haas lathe you can watch in in Graphics.
    O00010 (FACE&CHAMFER)
    N1 G20 G40 G80 G99 G61 G97
    N2 G53 G00 X-2. Z-15.
    N3 G50 S1800 (max spindle speed)
    N4 T101
    N5 S1000 M03 (starting spindle speed)
    N7 G00 X5.79 Z2. M08 (move to a safe distance for start)
    N8 G00 X5.79 Z0.15 (move to actual starting distance)
    N8 G96 S1600 (set constant surface speed CSS at 1600FPM for aluminum)
    N9 G72 P10 Q18 D0.03 U0.004 W0.004 F0.005 (face in .03 increments leave 0.004 for clean up)
    N10 G00 X5.78 Z0.
    N11 G01 X3.5 F0.004
    N13 X2.5
    N14 X0.
    N15
    N16
    N17
    N18
    N19 G70 P10 Q18 (take finish cut)
    N20 G97 G00 Z6.
    N21
    N22 M30
    Sep 2008
    8
    i guess at this point I still believe that z would be at the end of the part and negitive is cutting into the part I guess I'm not sure why this program is cutting at z-15.and dthe x is usualy programed off the center or the diameter so that seema ok. unless you mean that your g54 is setup off machine zero and then I think I would understsnd but then you would have to calculste that distance in your program. I guess to summ it all up I may not haver the experience that others may have. I can say that I have run a haas and fanuc controlers. please dont ask me to identify the model numbers. thanks joe please excuse the spelling it is now time to do honey doos
    Jul 2005
    12177
    Quote Originally Posted by josiahFRCC View Post
    i guess at this point I still believe that z would be at the end of the part and negitive is cutting into the part I guess I'm not sure why this program is cutting at z-15....
    You are referring to the G53 X-2. Z-15.0 line.
    G53 is machine coordinates so in fact this move takes the tool 15" from machine home on the Z and 2" away on the X.
    This program was written for a Haas TL2 and I use the G53 command instead of G28; G28 would take the machine all the way home which is 40 inches away from the chuck.
    The actual cutting moves start at line N7.
    The tool offsets are to the finished end of the part which is why line N8 has the tool positioned at Z0.15 just before the G72 canned cycle.
    The G72 faces the part down to Z0.0.
    Most times you would not need to take off this much material when facing.
    Nov 2006
    418
    bobrob,
    The link appears to have changed. Try this one "ftp://haascnc.net/Training/" then download the folder QC.
    Rgds,
    John B
    Apr 2008
    23
    tHANK YOU I WILL GIVE THIS A TRY TOMORROW WHEN I GO IN TO WORK ..
    Feb 2009
    lathe faceing canned cycle
    is it a fanuc control........if so.........
    G0 X1.5Z.05M8 (APPROACH)
    G72W.02R.01
    G72P020Q022U0W.01F.008
    N020G0Z0
    N022G1X-.035F.005
    G70P020Q022 (FINISH PASS)
    G0Z1.0M9
    X8.0Z8.0T0
    M1
    Apr 2008
    23
    could i also get a turning example ..program ??
    thank you in advance.. , Iam printing and saving all this in my work folder to help me out at work to keep my job .
  1. Lathe - internal facing tools?
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 03-09-2009, 07:26 PM
  2. Lathe Tapping Program
    By stoddgopats in forum G-Code Programing
    Last Post: 10-06-2008, 08:29 PM
  3. HAAS Lathe G94 Facing Can Cycle
    By nhatnam4 in forum G-Code Programing
    Last Post: 06-12-2008, 05:48 AM
  4. Program problems with my lathe....
    By Josh-PTP in forum Haas Lathes
    Last Post: 07-01-2007, 05:06 PM
  5. Hass VF6 how do you stop in middle of program
    By SpringKing in forum Haas Mills
    Last Post: 05-14-2007, 04:07 PM
