587,258 active members*
2,958 visitors online*
Results 1 to 3 of 3
    Jan 2009
    19
    Z-axis overrun on G30?
    Hello! First, let me say - I'm a newbie - I just got my K2 machine setup for the first time this weekend, and I believe I've run into my first issue, after tuning everything.
    My setup:
    K2 29x14x5 router frame
    Probotix Probostep motor kit w/ RF isolated breakout board
    Porter Cable 892 router
    Mach3 software
    Lead screws are 0.1", and the steppers are 200 steps @ 2x microstepping. I configured all axis for 4000 steps/inch.
    So, after some experimentation and a lot of reading of the documents, I got everything hooked up, including home switches on the k2. Everything is configured to do exactly as I would expect, and "calibration" on all axis always moves as far as I request it to. (As far as I can tell.)
    However... I have an issue with the Z axis, primarily, after several G0 commands moving all three axis around, one out of every five G30 commands will result in the Z axis overshooting zero (heck, overshooting the home switch, too). If I put the Z (or any other axis) just positive of home, they all ref to home properly. This doesn't seem to happen with the "Go to Zero" button in mach3, only in MDI w/ G30. (Of course, it could happen, and I just haven't experienced it yet!)
    I can't seem to find what's triggering the Z to overshoot, but on at least one occasion, it overshot enough for me to have to hit the E-stop before it burned up my motor.
    Any advice or suggestions on how I can eliminate this problem?
    Thanks very much!
    !c
    35538
    Try using G28 and set the G28 location in Config>Homing/Limits.
    Jan 2009
    19
    Thanks - that command seems to imitate the "go to zero" button (or vice-versa). -- moving the Z axis first and then the X and Y, instead of all three at once like G30, and hasn't overrun run in a dozen or so tries.
    !c
  1. the Difference of 2-Axis and 3-Axis of Vertical Mill Machine
    By begacon in forum Knee Vertical Mills
    Last Post: 07-30-2009, 12:31 PM
  2. post for 2 axis ez trak versus 3 axis ez vision
    By tooolman in forum G-Code Programing
    Last Post: 11-28-2008, 10:33 PM
  3. Compare Catia and MCX2 for multi axis lathe/4 axis mill
    By bob1112 in forum Uncategorised CAM Discussion
    Last Post: 10-11-2008, 01:15 AM
  4. How can I coupling a stepper motor axis directly to other axis?
    By meknik2001 in forum Stepper Motors / Drives
    Last Post: 05-08-2008, 07:54 PM
  5. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
