586,052 active members*
4,425 visitors online*
Results 1 to 8 of 8
    Dec 2007
    362
    X2 belt drive conversion
    I've just received a belt drive kit from LMS for my X2 mill.
    Clear instructions but I've come to a grinding halt trying to remove the black sleeve under the spindle nut.
    I can't remove it, it's just too tight.
    How tight should this be? The instructions don't mention any special tools being required.
    How can I remove it? I don't have any gear/bearing pullers.
    Regards
    Geoff
    Feb 2007
    4553
    Post
    Tumutbound,
    The spanner nut is a left hand thread.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Dec 2007
    362
    I got the spanner nut off ok, it's the black sleeve that will not come loose.
    Regards
    Geoff
    Feb 2007
    4553
    Post
    A large set of channel locks or a muffler clamp attached around the black ring and a few taps up with a rubber mallet should do it.
    There is a key and a keyway so trying to spin it wont work.
    Jeff...
    Feb 2007
    4553
    Post
    You may need to fabricate a collar type puller like this, if the other method does not work.
    The top of the collar would need bolts threaded through it, tightening the bolts would pull the sleeve off.
    Jeff...
    Dec 2007
    362
    Jeff,
    thanks for the suggestions. I'll try out the channel locks - tomorrow, it's late here.
    Regards
    Geoff
    Dec 2007
    362
    Well the pliers did the trick. It just needed a lot more force than I was using.
    Now all i need is 3/32" hex key to tighten the motor pulley (I'm a completely metric shop )
    Regards
    Geoff
    Feb 2007
    4553
    Red face
    Geoff,
    Drill and tap for a metric set screw.
    Jeff...
  1. Need Sherline Belt & qestion on X2 Belt Drive?
    By Oldboy in forum Benchtop Machines
    Last Post: 03-06-2008, 07:42 AM
  2. Belt drive conversion for X3?
    By phantomcow2 in forum Benchtop Machines
    Last Post: 07-17-2007, 12:31 AM
  3. HF 44991 belt drive conversion kit ????
    By mopar92 in forum Benchtop Machines
    Last Post: 12-21-2006, 07:20 AM
  4. Direct drive vs. Belt Reduction - Mini Mill Conversion
    By sanddrag in forum Benchtop Machines
    Last Post: 02-10-2006, 05:00 PM
  5. X3 conversion using big servos - direct or belt drive??
    By messar in forum Benchtop Machines
    Last Post: 01-27-2006, 10:19 AM
