HELP!!!! Someone please! I have a Harbour freight mill that i cnc retro'ed and here are the specs. Sanyo Denki Step syn motors, model# 103-845-6741 nema 34 frame, 12 to 300 volts,6.7 amp, 8wire, holding torque 486 oz/inch. rotor inertia=21.5 oz/inch, winding inductance=2 mh. They are wired in series unipolar mode for a current winding value of 6.7x0.707=4.74 amps. I am using Gecko drives G-201's. And a lambda regulated power supply model# lq-532 That has a max output or 40 volts, 5 amps.(It list for $1300. on their website, but i got it on ebay for $100.) The computer is a e-machine with amd k6-2/300mhz with 3-d now. 32mb sync DRAM/512 kb l2 pb cache,2.4 gb hard drive,ati rageIIc agp graphic card with 4 mb sdram. And a 98 works bundled O.S. I am also using Turbo cnc V.4 The problem is low torque. I have tried parallel wiring and series. I have tried every different current set resistor. I have tried every possible pulse width in turbo cnc. As well as every parameter in turbo. When i say low torque, i dont mean it wont move the table. I can lean against the table while jogging the mill and cant stop it. BUT if i grab the handwheel it locks up and the rotors just chatter away. Mind you its not missing steps or anything like that, but i know thats not right. Everyone keeps telling me "If it works, What do you care!" But the point is, 486 once/inch motors are not printer motors and you should not be able to stop them with LIGHT pressure on the hand wheels. I would be eternally greatfull to anyone that can help me solve this problem.
