586,075 active members*
4,219 visitors online*
Results 1 to 9 of 9
    Mar 2009
    5
    BDC 3200 control
    Hello
    I need help if someone can help me.
    Recently i buyed some old Bostomatic BD18 with BDC3200 contol,machine is in great condition but I have one big problem.
    The BDC control have Touchscreen and i started an Screen Calibrating,till then it was all good then somthing frezzed and i turn off the machine then I turn it on again but after that the touch screen dosen't respond and I cant get to start my machine,or get into any menu because it is all based on touch screen interface I have an classic pc keybord but I can't do anything with it.
    Please help or suggest if someone know anything.
    I hope that i post in right place.
    Mar 2009
    5
    Does someone know anything about Bostomatic machines?!
    Oct 2005
    4
    Try typing "config" then hit "enter", then type "calibrate" and hit enter. Touch lower left corner of the screen, then the upper right corner of the screen.
    Hopefully that will get your screen back.
    Kevin
    Mar 2009
    5
    Thanks Joeby.
    But
    I've tryed that for like 100 times and the screen doesn't react on my touch.
    I get the information from some people that I need some executive disc but I didn't get it with machine?
    Does somebody know anything about that??
    Oct 2005
    4
    I don't know how to help with that. The exec disk might be what you need to fix it. Ours was always kept in the bottom of the control cabinet
    I have no idea what support there is from Boston Digital now, just that it is now Mikron.
    Kevin
    Mar 2009
    5
    Yes I need the exec disk but I don't have it and the Mikron want's the hole fortune for generating the new one.
    So if some one have the Exec disk for Bostomatic BD18 and copy it that would help me allot,and then maybe I could start the machine.
    Till then I am desperate.
    May 2009
    Has Mikron told you if the disks are specific to that specific controller? I have exec disks for a BDC3200 but the controller is on a Vector machine.
    Mar 2009
    5
    Thanks for reply.
    It should work if the controler is BDC3200.
    But it won't work if the controler is BDC3200X because it is a newer software.
    I'am willing to risk if you would be so kind and send to me the copy of that exec disk because
    I dont have any other option to fix that.No one in my country or near my country dosen't have that type of machine.
    I don't understand what you mean by Vector machine?!
    This is my machine on this picture it is allsoo Vector!
    Please reply if you can.
    Thank you all from forum who are trying to help.
    May 2012
    17
    Re: BDC 3200 control
    Hello
    I'm looking for copy of EXE disk for Bostomatic BDC3200 or 4000 control
    I will appreciate a lot.
    Thank you !
    Manny
  1. Skimerator model 3200
    By Frank_S in forum Haas Mills
    Last Post: 06-12-2014, 10:01 PM
  2. Vanguard 3200 troubleshooting
    By LittleVoices in forum Engraving Machines
    Last Post: 06-23-2010, 07:15 PM
  3. Bostomatic 3200 Vector Control
    By beringer in forum Controller & Computer Solutions
    Last Post: 07-14-2009, 02:36 PM
  4. RPM beyond 3200?
    By Rich05 in forum Charter Oak Automation Support Forum
    Last Post: 03-31-2008, 12:44 PM
  5. Lincoln 3200 HD - a good buy?
    By damae in forum Welding Brazing Soldering Sealing
    Last Post: 08-18-2005, 07:59 PM
