586,060 active members*
3,555 visitors online*
    Sep 2004
    107
    MeshCAM vs. Deskproto
    I've been looking at DeskProto, but found that since it is prototype software it does some rounding when creating the part so the part that ends up being machined may not be within tolerances.
    Does MeshCAM have this same type of issue? Is this something inherent within the STL file type?
    In short if my part is 4 inches wide will it machine 4 inches wide no matter what type of bit is in the router/mill?
    -Matt
    CNC Blog:http://cutterscove.blogspot.com/
    Jan 2007
    219
    Meshcam will create the part exactly how the STL file is. It dose a very good job of creating g-code.
    -Adam
    www.adambrunette.com - Converting My Harbor Freight X2 And My Jet Jvm-830 Knee Mill, As well as many other projects.
    DeskProto shouldn't be doing any rounding. Perhaps the resolution of your .stl file is to low?
  1. Want to use DeskProto in place of DeskCNC for CAM
    By SCMW in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-10-2008, 03:54 AM
  2. My Initial Setup-Taig/Xylotex/Mach 3/DeskProto
    By John Bear Ross in forum Taig Mills / Lathes
    Last Post: 09-26-2007, 11:23 PM
  3. Rams3d Gold vs. DeskProto
    By robinsoncr in forum Rhino 3D
    Last Post: 05-10-2006, 02:18 PM
  4. Deskproto 4 Full pricing?
    By saturnnights in forum Uncategorised CAM Discussion
    Last Post: 03-08-2006, 07:15 PM
  5. Anyone using MeshCam?
    By groomden in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-26-2006, 01:07 AM
