Hey,
I'm about to start a project and would like some input before I put things in motion.
The belt driven spindle bypasses the gearbox and has top speeds of 2800 or 5900. Obviously only one belt is used at a time. The thickness is quite a bit less then that of the stock belt which is a bit discerning but I figure if something is going to fail, the belt should be the first thing to go. This belt is .354" and the stock is .545". I couldn't fit two bigger belts stacked like in this design and I couldn't get the speed range I wanted without changing the motor gear.
Coolant flows into the bottom left of the heatsink and two hoses will come off the bottom right side. The hope is to prevent the spindle from overheating.
The cad model is still a work in progress. Using solidworks 08.
Thanks for the peak
