I recently switched back from mazak lathe work to mazak mill
work on a new vcn510c. I have ran other mazak mills and never had
a problem with fixed tapping, but since I have been assigned to this
new machine the only way I can tap a hole without breaking a tap
is to use the peck2 cycle witch greatly adds to cycletime. Is there
a parameter from the factory set to something I need to change?.
or do I need to put in a T.P.C. with data? or do I need to stand on
one foot and rub my belly while it runs? Any help or suggestions would be
greatly appreciated.
DIEMAN1968
