I am in the hunt for Mil Spec (Cannon) connectors or an alternative. Any ideas? The part numbers are a bit intimidating and I lack familiarity with these plugs. They also seem rather pricey!
This is the best site I have found so far - http://www.alvatek.com/cms/products
I have used the plastic Amp plugs in the past but for the stepper power wires I think I would prefer a metallic shell for shielding purposes - or would I be OK to run these wires through a plastic Amp connector with the cable shield through one of the pins? I am not sure of which way to go and looking for suggestions.
In a nut shell - I am running the motor power cables seperately through multi-pin connectors and the rest of the control wiring through a larger, plastic Amp connector. This is so that the controller may be used on more than one machine.
Any help/experience/ideas/sources are welcome!
Scott
