586,597 active members*
3,548 visitors online*
    Jul 2007
    25
    need to change belt on hardinge vmc 1000
    I have a Hardinge Bridgeport VMC1000 p3 with the high torque option that I have been having trouble ridged taping with. I keep hearing a rattling noise as the tap is on its way out if Im running above 600rpm.The last time it did this I tightned the belt and the problem went away, this time it didn't .The machine has over 8000 hours on it so I figure it's time to change the belt.
    Has anyone had to do this, and if you have what do you have to take off to get to it?
    Thanks IKNEB
    Aug 2012
    9
    I am also looking for the proper procedure for belt change on this machine. It would be greatly appreciated.
  1. 2UVR Tree - Change Feed Belt
    By jimbogrif in forum Tree
    Last Post: 08-22-2011, 05:04 PM
  2. Replies: 5
    Last Post: 09-02-2008, 02:36 PM
  3. Hardinge HLV-H Lathe, change gears, 127 tooth
    By leeputman in forum Uncategorised MetalWorking Machines
    Last Post: 01-18-2008, 02:29 PM
  4. Replies: 1
    Last Post: 06-30-2007, 03:30 AM
  5. Hardinge Lathe Spindle Belt change
    By Ken_Shea in forum Bridgeport / Hardinge Mills
    Last Post: 09-12-2005, 07:39 PM
