586,080 active members*
3,833 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Advice about machine and used vacuum pump for holddown
    Jun 2008
    17
    In this my first post, I must start with saying: Thanks a million to all you contributors to this forum. So much help in the decision process. Have finally decided to equip my small 1 person shop with a CNC router for mainly cabinet work and built-in's.
    I am to import from USA to Sweden (in Europe) either a 5x10 EZ-router std with spindle or a 4x8 Shopbot std with spindle. The Shopbot cost slightly more. I can have both without table and legs which makes shipping less costly.
    Will build a vacuum table and had planned for using four vacuum cleaner engines (from these central units sitting in the basement).
    But now i stumbled upon a vacuum pump. The guy sent me a picture and he will sell it for the equivalent of $ 500. He didn't know more than it had been used for lifting some heavy materials. Only that it runs on 380 V 3-phase (std here in Sweden for heavier machines).
    Does anyone know if this a good deal and if it will work for me as a single vacuum unit? If you think its worth it, I will take a trip and examine it. What should I look for, in that case?
    I am grateful for any comments on this and of course also on my CNC choises.
    Jul 2005
    12177
    I cannot comment on your choice of machine but I can say I think you will find vacuum cleaners inadequate for a vacuum table and looking at the pump in the picture it may be inadequate because it looks like a centrifugal pump.
    For effective vacuum holding you need to be able to pull a vacuum equal to at least 0.75 atm and this is impossible with vacuum cleaner motors and a real strain for a multistage centrifugal pump. You really need a positive displacement pump such as a vane pump. I converted an old compressor into a vacuum pump and it worked very well.
  1. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
  2. OK, I've got my vacuum pump. Now what do I do with it?
    By DougO in forum Work Fixtures / Hold-Down Solutions
    Last Post: 07-09-2008, 08:35 AM
  3. Vacuum Pump
    By jfcamilo in forum DIY CNC Router Table Machines
    Last Post: 04-29-2008, 09:45 PM
  4. Here's some good information on making work holddown vacuum pods
    By buscht in forum DIY CNC Router Table Machines
    Last Post: 01-31-2005, 07:22 PM
  5. Where to get a vacuum pump
    By whiteriver in forum DIY CNC Router Table Machines
    Last Post: 05-11-2004, 04:47 PM
